The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
18 registered members (55 SHAKER, 48bigtrucks, beltfed, 3 invisible), 312 guests, and 3 spiders.
Forums47
Topics116,133
Posts923,468
Members42,352
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 42 of 42 1 2 40 41 42
Re: Disc brake conversion on a 46 2-ton [Re: RDomeck] #1309227 Thu May 02 2019 12:00 AM
bullethead67 Offline
Moderated
I have been following this thread but really I'm just more confused. I new to COEs and stovebolts. I would like to put this on my 46 COE. Will this bolt in or is it for the regular trucks? So far everything I have bought that should be bolt in and made for this truck is VERY far from it.
After reading I believe I need to check whitch kingpin I have? Is that correct? I need to ensure I have the larger one?
Also I saw where it says I keep my bolt pattern because I keep my hub? I don't understand this. Do I need to make sure I have a certain bolt pattern on my hub or something?
Will the brackets all work on a COE?
Will it all fit under the floor with a booster?
I have no idea if I have a 1.5 or 2 ton because my data plate is badly damaged.
Re: Disc brake conversion on a 46 2-ton [Re: RDomeck] #1310046 Wed May 08 2019 04:13 PM
Gert726 Offline
Originally Posted by RDomeck
He guys, life has been busy. I am still making these kits. I have some other guys wanting them and could get some put together in the next two weeks. I believe I have enough hub to rotor adapters and caliper brackets on the shelf for 5 kits.
Let me check on the parts on the shelf and I'll get back in touch with you guys.
Still interested in the kit Randy. Mark me down for a set
Re: Disc brake conversion on a 46 2-ton [Re: bullethead67] #1310962 Thu May 16 2019 10:54 PM
RDomeck Offline OP
Bullethead, I would really just need to know if you have screw on or bolt on dust caps on the front hubs. I have a 42 COE and I will check to see if these brackets will bolt up.
Randy Domeck
Indianapolis Fabrications
rdomeck@me.com
Indianapolis, In. 46254
317-258-0039
Re: Disc brake conversion on a 46 2-ton [Re: RDomeck] #1310963 Thu May 16 2019 10:58 PM
RDomeck Offline OP
I will have the parts pulled together next week for some kits. Life has been very busy and this project has been waiting on the back burner. I have moved some of those bigger projects off of my plate and will put some time and effort in to this.
Randy Domeck
rdomeck@me.com
317-258-0039
Re: Disc brake conversion on a 46 2-ton [Re: RDomeck] #1311444 Tue May 21 2019 10:08 PM
Gert726 Offline
awesome. Thanks man
Re: Disc brake conversion on a 46 2-ton [Re: RDomeck] #1311785 Fri May 24 2019 12:51 PM
JimmyBonz Offline
Are You the Guy that had the "Disc brakes Conversion for the 50 CHEVY 3/4 ton Trucks??? It was posted awhile back, but I was laid up with spinal fusion.READY NOW,to Tackle the 'Swap'. In Chicago Area..
" THANKS" for Any Help or Advice.
Jimmy Bones.
Jimmy Gatz
Moderated by  John Milliman, Tiny
Powered by UBB.threads™ PHP Forum Software 7.7.3
