The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
5 registered members (Shakey61, Hotrod Lincoln, EdPruss, 2 invisible), 272 guests, and 3 spiders.
Forums47
Topics114,975
Posts912,217
Members42,067
Most Online940
Apr 5th, 2017
Image Posting Policy
1946 Chevy 1/2 Ton #1311305
Mon May 20 2019 09:29 PM
Jrami386  Offline OP
Las Cruces, NM
Recently dusted off, what I'm assuming is a 1946 Chevy 1/2 ton. Found the ID plate (see attached). Everything is worn off except for a few stamped numbers. Called GM 1-800-222-1020 with no answers (maybe I just wasn't asking the right questions). Can anyone help me confirm this is a '46 Chevy 1/2 ton? I'm reading the numbers 46 stamped in the center of the plate with 5DP F 1252 stamped in the bottom right. Could that be the VIN? I appreciate your help!
Re: 1946 Chevy 1/2 Ton [Re: Jrami386] #1311306
Mon May 20 2019 09:34 PM
Justhorsenround  Offline
Grease Monkey
El Reno, Okla
Post a picture of your truck. Our eagle eyed experts will hopefully be able to ID it. Welcome to the Stovebolt madness. shake
"I fought the law and the law won" now I are a retired one!
Support those brave men/women who stand the "Thin Blue Line" and lock up those on the wrong side of that line.
Re: 1946 Chevy 1/2 Ton [Re: Jrami386] #1311315
Mon May 20 2019 10:01 PM
Jrami386  Offline OP
Las Cruces, NM
Take a look, a lot of work to be done but that's what makes it fun right.
Re: 1946 Chevy 1/2 Ton [Re: Jrami386] #1311316
Mon May 20 2019 10:12 PM
Grease Monkey
El Reno, Okla
Air the tires up, close the hood and drive it! drive
Re: 1946 Chevy 1/2 Ton [Re: Jrami386] #1311336
Tue May 21 2019 01:00 AM
46Sparky  Offline
USA
The “DP” would indicate the plate is for second series 1946 1/2 ton truck. The “F” would indicate a Flint, MI origin of manufature.
Re: 1946 Chevy 1/2 Ton [Re: 46Sparky] #1311353
Tue May 21 2019 03:22 AM
Mike B  Offline
Hughesville, MD
Sparky, you're close but not right...
5DP F 1252
5 = Kansas Plant
DP = 1946 3100
F = Month (June)
1252 = unit number starting at 1001
Mike B smile
Re: 1946 Chevy 1/2 Ton [Re: Jrami386] #1311360
Tue May 21 2019 03:57 AM
Jrami386  Offline OP
Las Cruces, NM
That's awesome info! Does anyone know where I can find the VIN?
Re: 1946 Chevy 1/2 Ton [Re: Jrami386] #1311378
Tue May 21 2019 01:03 PM
Grease Monkey
El Reno, Okla
The numbers you have provided is the vin or what we call a vin these days.
Re: 1946 Chevy 1/2 Ton [Re: Jrami386] #1311383
Tue May 21 2019 01:29 PM
tclederman  Offline
Boltergeist
Jarvisburg, NC
Here is serial number information/decoding for your truck.
The code you show was called a Vehicle Serial Number by GM/Chevrolet.
The other "ID"/serial number that was (sadly) used for "identification"/registration/titling purpose was the Engine Serial Number.
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 50 years
1954 3104 5-window pickup w/Hydra-Matic - part of the family for 14 years
Z-series (54/55) GMC 350 (2-ton) COE - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
Moderated by  Justhorsenround
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
