The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Happy New Year
2020
A New Year
A New Decade
A New Vision
Ring in the new with some quality time with your old truck! A great time to tackle a winter project. If you do not have access to your truck, start your parts list for spring!
The days are officially getting longer now, you know!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
13 registered members (Hotrod Lincoln, Apache1, Drew54, 78buckshot, 1953 panel, 1 invisible), 335 guests, and 3 spiders.
Forums48
Topics117,165
Posts936,223
Members42,795
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Intake alignment sleeves #1311328 Mon May 20 2019 11:58 PM
Ed Hotaling Offline OP
I have a 1953 factory replacement 235 in my truck. the alignment sleeves are missing, thus bad vacuum leaks. Does anyone know 1) where to get them, or 2) what the dimensions are so I can make a set out of locally obtained tubing?
Thanks in advance.
Ed
Re: Intake alignment sleeves [Re: Ed Hotaling] #1311333 Tue May 21 2019 12:50 AM
Justhorsenround Online
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
Google Chevy 235 intake/exhaust alignment sleeves. Several of the usual venders sell them. ๐Ÿ›
โ€˜65 Chevy Biscayne 4dr 230 I-6 one owner (Iโ€™m #2)
โ€˜39 Dodge Businessmans Coupe
"I fought the law and the law won" now I are a retired one!
Support those brave men/women who stand the "Thin Blue Line" and lock up those on the wrong side of that line.
Re: Intake alignment sleeves [Re: Ed Hotaling] #1311337 Tue May 21 2019 01:08 AM
Hotrod Lincoln Online
Boltergeist
Use pieces of exhaust pipe with a slice cut out and trim the length to fit the hole. It takes a little cutting and trying, but the sleeves don't seal vacuum. They only align the manifold so the gasket can do its job properly.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: Intake alignment sleeves [Re: Ed Hotaling] #1311346 Tue May 21 2019 01:46 AM
53 green 1- ton Offline
Ed,
I actually just installed my intake and had the same issue as you. I was able to use a or I believe it was a 1โ€ copper coupling cut to the correct length. As Jerry mentioned, there for alignment purposes only. You mentioned vacuum leaks. Make sure the intake/exhaust manifold are not warped. Hopefully just a thicker gasket will solve your issues.
Good luck,
Jim
Jim Schmidt.
Bucks County, Pa.
1953 3800
Pix in Photobucket
Re: Intake alignment sleeves [Re: Ed Hotaling] #1311348 Tue May 21 2019 02:00 AM
Wrenchbender Ret. Offline
I got a set at Classic parts a few months ago.
George
1956 Chevy 1/2-Ton Pickup
Re: Intake alignment sleeves [Re: Ed Hotaling] #1311351 Tue May 21 2019 03:09 AM
Dragsix Offline
The alignment rings can be obtained for $10 bucks and shipping.
https://www.ecklersearlychevy.com/c...216-and-235-ci-6-cylinder-1949-1953.html
Bad vacuum leak, try a rim flex gasket. They work really well. Really the best gasket I have ever used with my Clifford headers.
http://catalog.remflex.com/CHEVROLET_GM_CHEVY_Header_Exhaust_Manifold_Gasket_p/2027.htm
Mike
Re: Intake alignment sleeves [Re: Ed Hotaling] #1311354 Tue May 21 2019 03:23 AM
Jon G Offline
Just use a spring steel piece from a wooden crate strap. It is likely already the right width and once you get it cut it will stay in the hole without any work...remember it wants to be straight and flat.
Jon
1952 1/2 ton with 1959 235
T5 with 3.07 rear end
Re: Intake alignment sleeves [Re: Ed Hotaling] #1311368 Tue May 21 2019 10:44 AM
'54 3600 Offline
Here's what I used
https://i.postimg.cc/6QJs184n/Manifold-Seals-GM-NOS.jpg
Go to ebay & type in the part # in the search box
George
'54 3600
1954 3600
Re: Intake alignment sleeves [Re: '54 3600] #1311371 Tue May 21 2019 11:38 AM
tclederman Online
Boltergeist
Originally Posted by '54 3600
Here's what I used
George
'54 3600
Hmmm . . . . [five ? rings - listed as โ€œsealsโ€ ?]
Ask the eBay seller about the number of rings, before you buy.
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic - part of the family for 15 years
Z-series (54/55) GMC 350 (2-ton) COE - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
Re: Intake alignment sleeves [Re: tclederman] #1311372 Tue May 21 2019 11:43 AM
'54 3600 Offline
Right on the GM package it says , seal .
https://i.postimg.cc/SNVCt2Z5/235-Manifold-steel-ring-seals.jpg
Take it up with GM........I had nothing to do with it .
GM decided to package them ( 5 ) to a package ........why ?
George
'54 3600
1954 3600
Page 1 of 2 1 2
Moderated by  Woogeroo
Powered by UBB.threads™ PHP Forum Software 7.7.3
