Stovebolt is pleased to support the Salvation Army! We're doing fine but many around the World are not. Instead of making a contribution to us this holiday season, how about making your contribution to a great organization with a long history of helping people in need around the world?
0 registered members (),
263
guests, and 3
spiders. |
Key:
Admin,
Mod
Forums48
Topics116,488
Posts929,906
Members42,644
Most Online940 Apr 5th, 2017
Intake alignment sleeves
#1311328
Mon May 20 2019 11:58 PM
OP
I have a 1953 factory replacement 235 in my truck. the alignment sleeves are missing, thus bad vacuum leaks. Does anyone know 1) where to get them, or 2) what the dimensions are so I can make a set out of locally obtained tubing? Thanks in advance. Ed
Re: Intake alignment sleeves
[Re: Ed Hotaling]
#1311333
Tue May 21 2019 12:50 AM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
Google Chevy 235 intake/exhaust alignment sleeves. Several of the usual venders sell them. ๐
Martin '62 Chevy C-10 Stepside Shortbed (Restomod in progress) '47 Chevy 3100 5 Window (long term project) โ65 Chevy Biscayne 4dr 230 I-6 one owner (Iโm #2) โ39 Dodge Businessmans Coupe
"I fought the law and the law won" now I are a retired one! Support those brave men/women who stand the "Thin Blue Line" and lock up those on the wrong side of that line.
[Re: Ed Hotaling]
#1311337
Tue May 21 2019 01:08 AM
Boltergeist
Use pieces of exhaust pipe with a slice cut out and trim the length to fit the hole. It takes a little cutting and trying, but the sleeves don't seal vacuum. They only align the manifold so the gasket can do its job properly. Jerry
The murder victim was drowned in a bathtub full of Rice Krispies and milk. The coroner blamed the crime on a cereal killer! Cringe and wail in fear, Eloi- - - - -we Morlocks are on the hunt!
[Re: Ed Hotaling]
#1311346
Tue May 21 2019 01:46 AM
Ed, I actually just installed my intake and had the same issue as you. I was able to use a or I believe it was a 1โ copper coupling cut to the correct length. As Jerry mentioned, there for alignment purposes only. You mentioned vacuum leaks. Make sure the intake/exhaust manifold are not warped. Hopefully just a thicker gasket will solve your issues. Good luck, Jim
[Re: Ed Hotaling]
#1311348
Tue May 21 2019 02:00 AM
I got a set at Classic parts a few months ago.
George
[Re: Ed Hotaling]
#1311354
Tue May 21 2019 03:23 AM
Just use a spring steel piece from a wooden crate strap. It is likely already the right width and once you get it cut it will stay in the hole without any work...remember it wants to be straight and flat.
Jon
1952 1/2 ton with 1959 235 T5 with 3.07 rear end
[Re: '54 3600]
#1311371
Tue May 21 2019 11:38 AM
Boltergeist
Hmmm . . . . [five ? rings - listed as โsealsโ ?] Ask the eBay seller about the number of rings, before you buy.
