The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
14 registered members (JD1, BobF, DennisM, GMCanada9430, Hambone, 1 invisible), 307 guests, and 3 spiders.
Forums47
Topics115,104
Posts913,431
Members42,115
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 1 of 2 1 2
How often to check spare tire pressure? #1311331
Tue May 21 2019 12:27 AM
cmayna  Offline OP
Menlo Park, Ca
OMG, Today I got off my backside and checked the truck's tires pressure and all 4 were only 4-5# on the low side. The spare though contained only 50% of what it should.
Why? I never check the spare for it's under the bed, outa sight,,,,,,outa mind. When I had the '53 with a side bed spare tire carrier, that tire was loved....... grin
So, to you all, don't forget your spare tire!!
Craig's '50 Chevy 3100 5 window
My truck
If I'm not working on my truck or VW camper, I'm fishing with the wife or smoking Salmon.
Re: How often to check spare tire pressure? [Re: cmayna] #1311335
Tue May 21 2019 12:59 AM
Grigg  Offline
Lexington, VA
Probably should every time you check the four on the ground. Or at least before heading out on a long trip.. that's when I check them.
1952 Chevrolet 3800 pickup
---All pictures---
Re: How often to check spare tire pressure? [Re: cmayna] #1311345
Tue May 21 2019 01:44 AM
miraclepieco  Offline
OR
I check the spare on my daily driver at every oil change. That probably isn't often enough for my AD since I only change the oil in it once a year.
Here's something every driver should carry - seals AND inflates:
1951 Chevy Panel Truck
Re: How often to check spare tire pressure? [Re: cmayna] #1311361
Tue May 21 2019 04:10 AM
Grigg  Offline
Lexington, VA
I heard recently it also makes a mess of wheels and can damage wheel and or tire if not removed and cleaned.
Here's about all I could find about that on their site https://www.fixaflat.com/us/faq-faq-how-long-does-it-work.php
If that's true it might be cheaper and faster overall to take the time to deal with a flat or low tire in traditional ways, more air, plug and or patch, or even use the spare.
---All pictures---
Re: How often to check spare tire pressure? [Re: cmayna] #1311362
Tue May 21 2019 04:23 AM
Hotrod Lincoln  Offline
Boltergeist
Dellrose, TN
Fix-A-Flat ruins tires. The chemicals in it make it impossible for a patch to stick, no matter how deeply the rubber is buffed, or what kind of glue or solvent is used. Use it for emergencies, but be aware you'll have to replace the tire once you get wherever you're going.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: How often to check spare tire pressure? [Re: Hotrod Lincoln] #1311365
Tue May 21 2019 08:19 AM
OR
Have you actually ever used Fix-A-Flat, because that hasn't been my experience at all. I've used Fix-A-Flat about a dozen times. It's never caused any problems with subsequent patches. It's never stained my wheels. It's never dissolved my tires. It's never clogged my valve cores (the product Slime does that and I'm afraid that's where many of these erroneous rumors come from). I've used it in everything from my 4x4 to wheelbarrows to trailers to airplane tires. Twice it fixed the tire so good that I never got around to a "real" fix. You hook up the can to the valve stem, it seals the hole and inflates the tire in about 15 seconds, then you go get a permanent repair. No getting out the jack, no crawling around in the dirt and rain, no lugging a heavy dirty spare, no stuck lug nuts, etc etc.
But I understand how something that works this darn quick and easy is inevitably bound to have skeptics, so I'm prepared for the typical onslaught of internet horror stories from someone who read about a guy, who knew a guy, whose brother worked for a guy, who had a friend, who..... ;-)
Re: How often to check spare tire pressure? [Re: cmayna] #1311386
Tue May 21 2019 01:40 PM
cmayna  Offline OP
Menlo Park, Ca
I just want others to learn from my laziness. Check your spare more often than I have. Amen...
My truck
Re: How often to check spare tire pressure? [Re: cmayna] #1311389
Tue May 21 2019 02:11 PM
53 green 1- ton  Offline
Bucks County, Pa.
Craig,
I'll help get this back on track...…. Spare tires need air? ohwell Guess what I have to do? dang
Jim Schmidt.
Bucks County, Pa.
Pix in Photobucket
Re: How often to check spare tire pressure? [Re: cmayna] #1311401
Tue May 21 2019 03:49 PM
Boltergeist
Dellrose, TN
How about managing a road service and tire shop for 20-something years and teaching hundreds of high school kids how to service tires safely for 30 years after that- - - -is that enough reason to speak from experience? Fix-A-Flat ruins tires!
Re: How often to check spare tire pressure? [Re: cmayna] #1311402
Tue May 21 2019 04:04 PM
Bucks County, Pa.
Boy'z,
Can we stop with the hissy fits? Geez, it was a question made to have some fun with. Keep your ego's to yourself. The rest of us want to sit back and enjoy this site without getting the hair of my neck standing up!
Enjoy the day!
Jim
Jim Schmidt.
Bucks County, Pa.
Pix in Photobucket
Page 1 of 2 1 2
Moderated by  Justhorsenround
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
