The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
16 registered members (CATMAN, 51Craig1Ton, cmayna, FootStomper, artron9, 2 invisible), 318 guests, and 2 spiders.
Forums47
Topics115,012
Posts912,547
Members42,077
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 1 of 2 1 2
Intake alignment sleeves #1311328
Mon May 20 2019 11:58 PM
Ed Hotaling  Offline OP
Massachusetts
I have a 1953 factory replacement 235 in my truck. the alignment sleeves are missing, thus bad vacuum leaks. Does anyone know 1) where to get them, or 2) what the dimensions are so I can make a set out of locally obtained tubing?
Thanks in advance.
Ed
Re: Intake alignment sleeves [Re: Ed Hotaling] #1311333
Tue May 21 2019 12:50 AM
Justhorsenround  Offline
Grease Monkey
El Reno, Okla
Google Chevy 235 intake/exhaust alignment sleeves. Several of the usual venders sell them. 🛠
"I fought the law and the law won" now I are a retired one!
Support those brave men/women who stand the "Thin Blue Line" and lock up those on the wrong side of that line.
Re: Intake alignment sleeves [Re: Ed Hotaling] #1311337
Tue May 21 2019 01:08 AM
Hotrod Lincoln  Offline
Boltergeist
Dellrose, TN
Use pieces of exhaust pipe with a slice cut out and trim the length to fit the hole. It takes a little cutting and trying, but the sleeves don't seal vacuum. They only align the manifold so the gasket can do its job properly.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: Intake alignment sleeves [Re: Ed Hotaling] #1311346
Tue May 21 2019 01:46 AM
53 green 1- ton  Offline
Bucks County, Pa.
Ed,
I actually just installed my intake and had the same issue as you. I was able to use a or I believe it was a 1” copper coupling cut to the correct length. As Jerry mentioned, there for alignment purposes only. You mentioned vacuum leaks. Make sure the intake/exhaust manifold are not warped. Hopefully just a thicker gasket will solve your issues.
Good luck,
Jim
Jim Schmidt.
Bucks County, Pa.
Pix in Photobucket
Re: Intake alignment sleeves [Re: Ed Hotaling] #1311348
Tue May 21 2019 02:00 AM
Wrenchbender Ret.  Online
Lenexa Ks.
I got a set at Classic parts a few months ago.
George
1956 Chevy 1/2-Ton Pickup
Re: Intake alignment sleeves [Re: Ed Hotaling] #1311351
Tue May 21 2019 03:09 AM
Dragsix  Offline
Pennsylvania
The alignment rings can be obtained for $10 bucks and shipping.
https://www.ecklersearlychevy.com/c...216-and-235-ci-6-cylinder-1949-1953.html
Bad vacuum leak, try a rim flex gasket. They work really well. Really the best gasket I have ever used with my Clifford headers.
http://catalog.remflex.com/CHEVROLET_GM_CHEVY_Header_Exhaust_Manifold_Gasket_p/2027.htm
Mike
Re: Intake alignment sleeves [Re: Ed Hotaling] #1311354
Tue May 21 2019 03:23 AM
Jon G  Offline
Dallas, TX
Just use a spring steel piece from a wooden crate strap. It is likely already the right width and once you get it cut it will stay in the hole without any work...remember it wants to be straight and flat.
Jon
1952 1/2 ton with 1959 235
T5 with 3.07 rear end
Re: Intake alignment sleeves [Re: Ed Hotaling] #1311368
Tue May 21 2019 10:44 AM
'54 3600  Online
New Jersey Shore
Here's what I used
https://i.postimg.cc/6QJs184n/Manifold-Seals-GM-NOS.jpg
Go to ebay & type in the part # in the search box
George
'54 3600
1954 3600
Re: Intake alignment sleeves [Re: '54 3600] #1311371
Tue May 21 2019 11:38 AM
tclederman  Offline
Boltergeist
Jarvisburg, NC
Originally Posted by '54 3600
Here's what I used
George
'54 3600
Hmmm . . . . [five ? rings - listed as “seals” ?]
Ask the eBay seller about the number of rings, before you buy.
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 50 years
1954 3104 5-window pickup w/Hydra-Matic - part of the family for 14 years
Z-series (54/55) GMC 350 (2-ton) COE - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
Re: Intake alignment sleeves [Re: tclederman] #1311372
Tue May 21 2019 11:43 AM
'54 3600  Online
New Jersey Shore
Right on the GM package it says , seal .
https://i.postimg.cc/SNVCt2Z5/235-Manifold-steel-ring-seals.jpg
Take it up with GM........I had nothing to do with it .
GM decided to package them ( 5 ) to a package ........why ?
George
'54 3600
1954 3600
Re: Intake alignment sleeves [Re: Ed Hotaling] #1311374
Tue May 21 2019 11:56 AM
tclederman  Offline
Boltergeist
Jarvisburg, NC
The Master Parts Catalog lists that part number as having 3 sleeves per pack.
http://chevy.oldcarmanualproject.com/1929_57chevyparts/57cmpc0268.htm
Some reproduction parts vendors sell them in sets of 3 and others in sets of six? [thanks, Jerry]
Tim
Re: Intake alignment sleeves [Re: Ed Hotaling] #1311381
Tue May 21 2019 01:14 PM
Boltergeist
Dellrose, TN
Since a stovebolt engine only has three intake ports to deal with, why do the resto-ripoff guys sell the sleeves six at a time? Price gouging, or just ignorance?
Re: Intake alignment sleeves [Re: Ed Hotaling] #1311417
Tue May 21 2019 05:12 PM
coilover  Offline
Plano, Tx
I have a 263 straight eight in my 37 Buick and it cracked two exhaust manifolds which are getting hard to find. A friend that ran a small block Chrysler in his circle track car which isn't an engine that every FLAPS carries header gaskets for clued me in on red high temp silicone. I then used neither alignment rings or gaskets which I figured might let the manifold "creep" between hot and cold. That was twenty years ago and still holding with no leaks--exhaust or vacuum. The manifold and head MUST be surgically clean before applying sealant.
[img]https://i.postimg.cc/Rq34bd8V/Pont-heater-Buick-sealant-003.jpg[/img]
Evan
Re: Intake alignment sleeves [Re: Ed Hotaling] #1311468
Wed May 22 2019 02:21 AM
52Carl  Offline
Virginia
Dang, Evan. Now I'm not saying that you are crazy, but it is crazy to me that the high temp silicone would withstand the exhaust heat. But then, since there is no gasket there, the silicone got squished pretty thin so it can't really get blown out.
It reminds me of how anaerobic sealant works on sealing the 2 halves of 2-cycle outboard case. It must be squished very thin to work. It also has to withstand some high heat conditions.
Re: Intake alignment sleeves [Re: Ed Hotaling] #1311484
Wed May 22 2019 10:11 AM
'54 3600  Online
New Jersey Shore
There are GM NOS ( 3 ) intake manifold sleeves on ebay right now
$12.00..........they are in excellent near mint condition .
Fits 1950 to 1962 ALL ( ex.216 )
Go to ebay & in the search box.......type........3835506
PIC
https://i.postimg.cc/bvhKcZLf/3835506aa.jpg
They have the correct factory specs - correct thickness - the correct spring action & the correct depth & the correct I.D. & O.D. when closed
and are made in the U.S. A.
Certainly better then out of spec homemade .
So , why buy made in china fake repro's .
Here's a GM NOS set that sold on ebay last month for $7.00 .
PIC
https://i.postimg.cc/j5br9XmN/3835506e.jpg
GM NOS for less then chinese fake junk .
George
'54 3600
1954 3600
Re: Intake alignment sleeves [Re: Ed Hotaling] #1311489
Wed May 22 2019 12:51 PM
V
Volfandt  Offline
Knox County, TN
I put 23K trouble free miles on a 216 sans those rings..... When I R&R'ed the head the originals were toasted beyond reuse so I installed the manifolds without them as I really wanted to see if the engine would run. It did and the need never arrose (?) for said rings.....
I did install those rings on my 235, haven't put any miles on it yet but it's getting oh so close...
I don't believe those rings will stem an intake or exhaust leak, IMHO they are to keep the gaskets inline whilst installing the manifolds, IMHO ofcourse LOL...
Re: Intake alignment sleeves [Re: Ed Hotaling] #1311499
Wed May 22 2019 02:20 PM
Boltergeist
Dellrose, TN
Getting an assembly as heavy as the intake/exhaust manifolds perfectly aligned so the gasket seals correctly is a matter of being lucky, not necessarily good, in most situations. It's a lot more likely to happen with those three little pieces of tubing in place. The suggestion about using a piece of steel crate banding strap is one I'm definitely going to remember! There's also a set of dual-diameter rings available to make a 216 manifold fit a 235 head, or the other way around.
Re: Intake alignment sleeves [Re: Ed Hotaling] #1311663
Thu May 23 2019 04:48 PM
coilover  Offline
Plano, Tx
Yeah, Jerry, I'm not good, lucky, or smart so Buick did me a favor and used dowl pins at the front and rear of the exhaust manifold rather than bolts---kind of makes alignment dummy proof.
Evan
Re: Intake alignment sleeves [Re: Ed Hotaling] #1311943
Sat May 25 2019 11:09 PM
Massachusetts
Like Jerry said, getting the gaskets in place without the sleeves is quite a task. I have had issues with it in the past and want to get this thing running properly. Thanks for all the suggestions. I may try the banding iron method if I can get my hands on a piece.
Ed
Re: Intake alignment sleeves [Re: Ed Hotaling] #1311951
Sun May 26 2019 01:15 AM
Mike B  Online
Hughesville, MD
Why make them when all the vendors sell them...
https://www.classicparts.com/1934-5...6wJC4oy4N3sCscuUSb6Ke_7epU4aAnEgEALw_wcB
Mike B smile
Page 1 of 2 1 2
Moderated by  53moneypit, Woogeroo
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
