The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
8 members (k10, Skooter, NorthCoast3800, JiMerit Boltr#43, drdoug, 9% grade), 84 guests, and 3 robots.
Forums50
Topics119,601
Posts957,693
Members43,440
Most Online1,229
Jan 21st, 2020
Image Posting Policy
1953 GMC Gas Tank Install
#1311299 Mon May 20 2019 08:49 PM
I am putting a new Spectra gas tank (inside cab) in my 1953 GMC. My question is the old one I removed did not have a shut off valve on the nipple from the tank under the car, should I install one when I put the new tank in ? Any specific type ?
Re: 1953 GMC Gas Tank Install
buckaroo01 #1311320 Mon May 20 2019 10:22 PM
Get the one from Jim Carter truck parts--I just did..
buckaroo01 #1311334 Tue May 21 2019 12:59 AM
When I replace a tank, I like to plug the hole in the bottom of the tank and upgrade to the type of sending unit which has the fuel pickup attached to it, heading down into the tank from the top. It has a nice filter sock on the end of it and you will never have another issue of crud settling in the hole in the bottom of the tank, causing a miserable intermittent blockage of fuel.
The one you need is for a '54-'59.
You will need to route a fuel line through the floor, up along the front of the tank, then to the fitting on the sending unit. Copper-nickle line makes this chore a breeze. No bending tool required.
Carl
Moderated by  Woogeroo
