The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
7 members (AwDang, 1953 panel, Johnny N, Dusty, Barnfind49, 1 invisible), 239 guests, and 3 robots.
Forums50
Topics120,034
Posts961,345
Members43,542
Most Online1,229
Jan 21st, 2020
Image Posting Policy
1954 3604 - How do you ? - Original Hubcaps on Dexstar 16" x 6" Rims
#1311070 Sat May 18 2019 05:04 PM
Dusty53 Offline OP
Has anyone installed Original 1954 3/4 Ton Hubcaps onto the Dexstar , AM20766, 16" x 6" Rims ? If yes, what is required to do this retro-fit ?
Ronnie
1954 Chevy 3604 - A work in progress...
" You can't keep dancing with the Devil and wonder why you're still in hell"
Re: 1954 3604 - How do you ? - Original Hubcaps on Dexstar 16" x 6" Rims
Dusty53 #1311086 Sat May 18 2019 08:50 PM
There are several ways to adapt the original hubcaps to fit the modern rims. This link is just off the top of my head....
https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/1273663/1.html
Dusty53 #1311096 Sat May 18 2019 11:03 PM
Dusty53 Offline OP
Thanks M.T. , following that thread.
Ronnie
Dusty53 #1311284 Mon May 20 2019 07:14 PM
Shop Clutterist
Your wheels have the bumps to hold the hubcaps on. My wheels also have the bumps. I made correct era appearing hubcaps using 1970s era caps and repro caps.
Gord
1954 1/2 ton 235 4 speed
Dusty53 #1311709 Thu May 23 2019 11:49 PM
Dusty53 Offline OP
Gord, those are beautiful. So far the problem I've run into is the depth of the hubcap being the issue on the 3/4 truck due to the size and length of the wheel hubs. Not sure what direction to go in now.
Ronnie
Dusty53 #1311750 Fri May 24 2019 03:44 AM
Shop Clutterist
Years ago, I posted a description of how I made those. However, it seems that many of my older posts have vanished. I still have the pictures, so I can re-post. My rims are 15" - not sure if the donor caps fit both 15 and 16" rims. Anyway, the mating of the two caps makes the hubcap deeper so it's allows for more space for the hubs.
Gord
Dusty53 #1311780 Fri May 24 2019 12:41 PM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
Gord if you would write it up as a Tech Tip and submit it directly to editor@stovebolt.com (John Milliman) it can be kept here forever. It would be a great addition to our Tech Tips section.
ā€˜65 Chevy Biscayne 4dr 230 I-6 one owner (Iā€™m #2)
ā€˜39 Dodge Businessmans Coupe
USAF 1965-69 Weather Observation Tech (got paid to look at the clouds)
"I fought the law and the law won" now I are a retired one!
Dusty53 #1311814 Fri May 24 2019 05:11 PM
Shop Clutterist
Hi Martin,
I re-posted it last night here: https://www.stovebolt.com/ubbthread...e-vintage-hubcaps-fit-modern-wheels.html
Tech tip? Well, it's just one solution to a problem as Mother.Trucker wrote above.
Gord
Moderated by  HandyAndy, klhansen
