The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
16 registered members (5 Window 9434, 52Stove, 78buckshot, ApacheFiend, Barnfind49, 1 invisible), 309 guests, and 3 spiders.
Forums47
Topics116,116
Posts923,325
Members42,345
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 2 of 2 1 2
Re: Glass bowl fuel pump [Re: roberts49chevy] #1311026 Fri May 17 2019 11:33 PM
roberts49chevy Offline OP
My first attempt at installation of fuel pump was not successful. I’m sure there is trick to it. When putting the pump against the block the gasket is moving. I had to permatex the gasket to the block. After the gasket dries, when I try to assemble the pump and I push and wiggle the pump so the bolts line up, the arm of the pump goes upward. Is this correct?
Re: Glass bowl fuel pump [Re: roberts49chevy] #1311243 Mon May 20 2019 12:34 PM
Update.After a lot of struggling I managed to get it bolted on. Mission accomplished. Now I’m waiting for a new gas line pump to Carb and then I can start it. I hope there are no leaks. 🤞
Re: Glass bowl fuel pump [Re: roberts49chevy] #1311257 Mon May 20 2019 02:49 PM
Hotrod Lincoln Offline
Boltergeist
Even with the camshaft lobe at its low point, there's a fair amount of spring pressure against the fuel pump lever arm. If you happen to try installing the pump with the high point of the cam lobe facing outward, there's a LOT of spring pressure to deal with. That's why some of the above comments recommend turning the engine over until the cam lobe is facing away from the hole in the block. Once you install a few dozen pumps, the procedure becomes pretty routine. At least with a stovebolt six you don't have to deal with a pushrod that slides down and blocks installing the pump, like happens on a Chevy V8 engine!
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: Glass bowl fuel pump [Re: roberts49chevy] #1311912 Sat May 25 2019 03:48 PM
So I completed the job. Oil pump and truck run great and no leaks! Thank for your help.
Page 2 of 2 1 2
Moderated by  Woogeroo
Powered by UBB.threads™ PHP Forum Software 7.7.3
