The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Nothing new here ...
STOVEBOLT FEVER
There is no cure!
Thanks to all of you, we have been virtual for over 25 years.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
17 members (artinva, chahn1980, baldeagle, don orland kid, Achipmunk, 2 invisible), 316 guests, and 4 robots.
Forums47
Topics117,812
Posts942,665
Members43,045
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 3 of 3 1 2 3
Re: Woah! She’s slow.
Skidmarks #1310158 Thu May 09 2019 06:17 PM
You can get a 3.38 gear for the '55-'59 (and up through '64?) half ton rear end, but I'd suspect you'd be feeling slow from starts with that versus slow up top with what you've got. I'd be willing to bet, based on my experience with my '50 half ton 3spd/4.11 and 216, that you aren't actually pulling as many rpms as it sounds like it is at speed.
Skidmarks #1310168 Thu May 09 2019 07:46 PM
'63 is a different axle.
3.90:1 was stock.
I know you can cruise 65mph all day with a 235 & 3.90 rear axle because I drove To MA & back to OR several years ago. with no issues. Changed oil on the east coast before heading back. Still running same engine now, doesn't use oil. If it's in decent condition & valves are adjusted will not be an issue. Used to run 80 MPH with it back in high school (1970s) road racing a buddy with a Jeep wagoner hurricane 6.
BC
1960 Chevy C10 driver
1960 C60 pasture art
G.M dealer tech since 1980 & counting
Skidmarks #1310216 Fri May 10 2019 01:02 AM
I replaced the Eaton HO52 rear end in my 49' 3600 with a Dana 60 from a 69' F250. Almost exact same width backing plate to backing plate. I had the drive shaft shortened by about 2.5 inches and a yoke welded on to mate up to the Dana 60. It has a 3.73 ratio along with 29" diameter tires and I can hit 60MPH at 2500 RPM with the stock 4 speed transmission.
1949 Chevy 3600
1975 W-25 Hurst Olds
1991 Chevy Silverado
1970 GMC 1/2 ton Fleetside
2010 Chevy Silverado
I'm a GM man!
bztguy #1310279 Fri May 10 2019 03:47 PM
Skidmarks rig is a 1/2 ton
BC
Skidmarks #1310281 Fri May 10 2019 04:07 PM
Axle ratio, tire diameter, and engine RPM are useful for comparison regardless of truck model.
1952 Chevrolet 3800 pickup
---All pictures---
Skidmarks #1310283 Fri May 10 2019 05:11 PM
Boltergeist
Back in the mid-1960's I ran a 58 Chevy 2 door sedan with a 235, 3 speed, and a 3.70 rear end. It had low profile 14" tires on it, standard for that model. I had no trouble keeping up with traffic at 65-70 MPH, and the mid-80's were not too difficult. With 3.90 gears and the same 1:1 high gear ratio in the transmission, a bone-stock pickup with a 235 should be able to do similar speeds because of the taller tires.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Skidmarks #1310423 Sat May 11 2019 11:33 PM
Shop Clutterist
Today, I stuck the GPS onto the windshield and took the truck out on the highway. At 90 KPH (about 55 MPH), the speedometer indicated 40 MPH; this speedometer error is pretty close to what I calculated it would be. Engine RPM is about 1750 at this speed in 4th gear.
Rear axle ratio is 2.41. Tires are 767 revs/mile.
Gord
1954 1/2 ton 235 4 speed
Skidmarks #1311226 Mon May 20 2019 01:44 AM
So I was looking into a different differential. Will a new ring gear and pinion work? Are these old rear ends compatible with a new ring gear swap or am I wasting my energy?
1958 Chevy Apache Fleetside/235/3 sp
Pictures at http://www.facebook.com/album.php?aid=317454&id=855355703&l=0a0f773195
Skidmarks #1311229 Mon May 20 2019 02:03 AM
ace skiver
"1958 Apache 235/3 speed . . .
Will a new ring gear and pinion work?"
As EBS posted above
If you go that way, you might want to also use this installation kit.
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
Z-series (54/55) GMC 350 (2-ton) COE [1954advance-design.com] - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
tclederman #1312811 Sat Jun 01 2019 07:52 PM
As EBS posted above
You can get the install kit MUCH cheaper at Jeg's.
Page 3 of 3 1 2 3
Moderated by  SWEET
