The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
11 registered members (honk1e, archburycontrol, Hotrod Lincoln, 3 invisible), 310 guests, and 3 spiders.
Forums47
Topics115,749
Posts919,904
Members42,330
Most Online940
Apr 5th, 2017
Image Posting Policy
rubber fuel hose woes #1311121 Sun May 19 2019 02:50 AM
52Carl Offline OP
The flexible rubber hose which goes between the bottom of the gas tank and the hard line heading to fuel pump has failed once again. The most resent one failed in a few months! The 10% alcohol formula of gasoline dissolves it, turning it into mush. I got both of them from a reputable vendor, but apparently their source failed chemistry in school, based on their choice of "rubber."
Has anyone else had this problem?
I am not looking for an original looking hose. I just want some type of flexible fuel line down there which can actually withstand contact with gas (not too much to ask, one would think).
The two ends which I am trying to put a flex line between are 5/16" flared fittings.
Carl
Re: rubber fuel hose woes [Re: 52Carl] #1311122 Sun May 19 2019 03:02 AM
Justhorsenround Offline
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
Gates green stripe is suppose to be for corn squeezins!
"I fought the law and the law won" now I are a retired one!
Support those brave men/women who stand the "Thin Blue Line" and lock up those on the wrong side of that line.
Re: rubber fuel hose woes [Re: 52Carl] #1311136 Sun May 19 2019 10:30 AM
moparguy Offline
If the parts counter has a knowledgeable person, tell em you need fuel line for a (2000 ish of your choice car) with fuel injection. It'll be rated for today's fuel and the higher pressures of a fuel injection system. I've had no issues since using this method of buying fuel hose.
1970 340 Duster
1951 Farmall Super A
Re: rubber fuel hose woes [Re: 52Carl] #1311140 Sun May 19 2019 11:53 AM
Grigg Offline
See if this makes sense, a recipe (copied and pasted from an email to a friend a few years ago) for hose similar to original but with reusable ends and better hose.
Here is the catalog with the Barb-Tite or "Push-loc" hose fittings (and hose). These don't need hose clamps.
http://www.eaton.com/ecm/groups/public/@pub/@eaton/@hyd/documents/content/pll_1189.pdf
Page K-6
You need part number 10005B-A05 to make the connection between the steel line and rubber hose.
With original fuel valve you'd also use part number 10005B-B05 to make up a reusable fuel line similar to the non reusable original.
The hose to use is H10005 on page C-2
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Re: rubber fuel hose woes [Re: 52Carl] #1311213 Mon May 20 2019 12:22 AM
52Carl Offline OP
Thanks to all!
Moderated by  53moneypit, Woogeroo
Powered by UBB.threads™ PHP Forum Software 7.7.3
