The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
14 registered members (Brad Allen, delky, Bill Marlow, BorderMechanical, 55 SHAKER, 5 Window 9434), 336 guests, and 3 spiders.
Forums48
Topics116,181
Posts923,868
Members42,360
Most Online940
Apr 5th, 2017
Image Posting Policy
1951 Chevy 6400 differential problem #1311166 Sun May 19 2019 05:04 PM
Bradman Offline OP
Moderated
Hi. New to the forum so I hope I’m doing this right. I’m looking for a source for rear end spider gears for the truck. Thanks for any information.
Re: 1951 Chevy 6400 differential problem [Re: Bradman] #1311176 Sun May 19 2019 07:00 PM
3B Offline
Hy Bradman, welcome, could you provide some pictures of the differential and or any numbers you may find on the differential? If I am remembering correctly that truck came from the factory with a Timken double reduction two speed differential, but a lot could have happened in the last 68 years to change that. Is your wheel mounting pattern the same for both the front and rear axles? The Timken double reduction two speed differential is quite large and probably projects out a foot or more from the differential housing. There is a tutorial on posting pictures on the bottom left of this page, hope that helps.
Re: 1951 Chevy 6400 differential problem [Re: Bradman] #1311222 Mon May 20 2019 01:13 AM
EdPruss Offline
Sometimes it is more productive to get a modern rear axle with the same wheel bolt pattern, those original gears are low and lower ratios, making for slow progress on the road.
Ed
Re: 1951 Chevy 6400 differential problem [Re: Bradman] #1311285 Mon May 20 2019 07:41 PM
Bradman Offline OP
Moderated
Thanks for the info
The top of the differential numbers are:
AN 430 613
830
D5. 51
Back tires are 8.25x20
Fronts are 7.50x20
I’ve thought about replacing the rear end. I have a 1967 international 1600 with a 2 speed rear end that measures about the same width. I don’t take the truck on the highway. I use it around town so the slow speed is ok. I have a mechanic that works on rear end everyday and he is telling me if I can find the parts he can fix the rear end.
Moderated by  69Cuda, Grigg
Powered by UBB.threads™ PHP Forum Software 7.7.3
