The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
3 registered members (Jon Patton, 53RLT56, Hotrod Lincoln), 289 guests, and 2 spiders.
Forums47
Topics114,990
Posts912,329
Members42,071
Most Online940
Apr 5th, 2017
Image Posting Policy
52 3100 Extra Crossmember #1311165
Sun May 19 2019 05:02 PM
Phak1  Offline OP
Upstate NY
While looking for the source of my throwout bearing noise issue, I noticed a crossmember directly under the tail shaft of my manual 3 speed. It is not connected to the transmission as the rear mounts are on the bell housing. It is however bolted to the frame and not riveted to the frame. Looking in the assembly manual, the only crossmember is see in that position, is for an automatic transmission.
Now that’s got me thinking. I know that several parts of my truck have been replaced (the cab is originally green, the fenders originally blue and the bed is red. The engine is from a 1959 235, etc., etc...).
The bracket for the brake and clutch return springs are riveted to the frame indicating it was setup for a standard. What is that extra crossmember for?
1952 Chevrolet 3100 w/59’ 235
Re: 52 3100 Extra Crossmember [Re: Phak1] #1311168
Sun May 19 2019 05:18 PM
cmayna  Offline
Menlo Park, Ca
Looks like a stock bolt on rear cross member for a SM420 gearbox.
Craig's '50 Chevy 3100 5 window
My truck
If I'm not working on my truck or VW camper, I'm fishing with the wife or smoking Salmon.
Re: 52 3100 Extra Crossmember [Re: Phak1] #1311173
Sun May 19 2019 05:44 PM
Greg Brown  Offline
Bellevue, WA
There's been a lot of debate about which years/models had rear transmission supports, but since you have the cross member, it would seem your truck originally had the support. It looks like you're missing the pieces that go between that cross member and the transmission.
Greg Brown
'49 Chevy 3100
Re: 52 3100 Extra Crossmember [Re: Phak1] #1311178
Sun May 19 2019 07:14 PM
tclederman  Offline
Boltergeist
Jarvisburg, NC
That frame cross member was used on all 1/2 ton trucks through 1953. I assume it was also used/needed on all sizes of trucks through 1953 (and, with 3-speed and 4-speed transmissions)?
Many people report it missing, but it was probably removed when a transmission was removed, and then not replaced.
There was no need for that rear-of-transmission cross member in 1954 with standard transmissions, because the rear engine-mount crossmember changed in 1954.
The 1954/55st Hydra-Matic transmission trucks did have a rear-of-transmission cross member, but it was only needed with the H-M transmission (and, it was bolted-on/removable).
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 50 years
1954 3104 5-window pickup w/Hydra-Matic - part of the family for 14 years
Z-series (54/55) GMC 350 (2-ton) COE - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
Re: 52 3100 Extra Crossmember [Re: Phak1] #1311185
Sun May 19 2019 08:15 PM
Phak1  Offline OP
Upstate NY
Should I be concerned that it is not mounted to the transmission?
Re: 52 3100 Extra Crossmember [Re: Phak1] #1311190
Sun May 19 2019 09:08 PM
tclederman  Offline
Boltergeist
Jarvisburg, NC
I would try to find a mount (or, use the mount, if you have one).
If you need the mount, post a Parts Wanted ad.
Or, Classic Parts sells the assembly the replacement pads.
https://www.classicparts.com/searchprods.asp
Tim
Re: 52 3100 Extra Crossmember [Re: Phak1] #1311200
Sun May 19 2019 10:53 PM
Phak1  Offline OP
Upstate NY
Wow! I just viewed the post “Rear transmission support sm420” and this debate has been going on quite some time. It seems to me the common denominator for using this crossmember is the torque tube. I’m convinced, I need to buy and install the rear transmission mount.
Re: 52 3100 Extra Crossmember [Re: Phak1] #1311216
Mon May 20 2019 12:41 AM
52Carl  Offline
Virginia
I have always wondered if that cross member was added to tame something like a vibration issue in that area caused by a less than adequate rear bellhousing mount design. This theory is strengthened due to the fact that the bolt-on crossmember was eliminated in "54 when a more stout bellhousing mount design was incorporated.
The mount on the '53 and earlier bolt-on crossmember is a flimsy affair at best. It really doesn't support much. If fact, as the small rubber pads deteriorate over time, I have never noticed any difference in operation of the trucks which I have driven.
Carl
Re: 52 3100 Extra Crossmember [Re: Phak1] #1311227
Mon May 20 2019 01:48 AM
tclederman  Offline
Boltergeist
Jarvisburg, NC
Tim
Moderated by  SWEET
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
