The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
18 registered members (Hotrod Lincoln, 55 SHAKER, 59 fleet, chevyfiftynine, ASU, Dusty53), 300 guests, and 3 spiders.
Forums47
Topics115,770
Posts920,113
Members42,336
Most Online940
Apr 5th, 2017
Image Posting Policy
Removing front clip or not? #1311072 Sat May 18 2019 05:26 PM
Kilted54 Offline OP
This is my best guess as for appropriate forum for this question
I’m going to be replacing the intake (to offenhauser and need to plumb water heat) and exhaust manifold (Williams) soon and a power steering upgrade when kit arrives.
I got a belly (sadly the reason for power steering as I need a smaller wheel) which adds to challenge of reaching in over vendors.
Background for question done:
Q1: For those who have did manifold replacement w/ engine in, did you remove front clip?
Q2: if You didn’t, did you wish you did?
Q3: if you did, do you wish you didn’t
Note: I plan on leaving hood on.
I know I should just wait to do all at once
Any thoughts will be greatly appreciated
Re: Removing front clip or not? [Re: Kilted54] #1311078 Sat May 18 2019 06:22 PM
tclederman Offline
Boltergeist
Q1: no
Q2: no
Q3: no
I might not correctly understand what you are doing.
“I know I should just wait to do all at once”
What should you do all at once?
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 48 years
1954 3104 5-window pickup w/Hydra-Matic - part of the family for 14 years
Z-series (54/55) GMC 350 (2-ton) COE - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
Re: Removing front clip or not? [Re: Kilted54] #1311081 Sat May 18 2019 06:32 PM
sstock Online
Well having a belly can be meant to mean two different extremes. If you cannot reach the manifold bolts leaning over the fenders then you do need to remove the fenders if you are already standing on a stool.
Otherwise, like Tim says, no,no,no to your questions.
1953 Chevrolet 3100
261 cu inch, sm420, 3.55 rear, omaha orange, still 6 volt, RPO green glass, side carrier spare
https://www.youtube.com/watch?v=Bli...n05i04t1aokgm4p04jiwgffwhyyih5xbk0h00410
Re: Removing front clip or not? [Re: Kilted54] #1311082 Sat May 18 2019 07:01 PM
Wrenchbender Ret. Online
I think that belly would be more in the way removing the front clip then the manifold.
I have bad knees & shoulder. I usually jack the back end of the truck up high to help reach things under the hood.
George
1956 Chevy 1/2-Ton Pickup
Re: Removing front clip or not? [Re: Kilted54] #1311083 Sat May 18 2019 08:12 PM
Justhorsenround Offline
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
Absolutely not. Just opening a big can of worms.
"I fought the law and the law won" now I are a retired one!
Support those brave men/women who stand the "Thin Blue Line" and lock up those on the wrong side of that line.
Re: Removing front clip or not? [Re: Kilted54] #1311109 Sun May 19 2019 12:40 AM
miraclepieco Offline
I use my engine hoist to reach over the fenders into the engine compartment and lift out heavy parts such as manifold or head.
1951 Chevy Panel Truck
Re: Removing front clip or not? [Re: Kilted54] #1311129 Sun May 19 2019 04:35 AM
mick53 Offline
Plenty of room in there.
Re: Removing front clip or not? [Re: Kilted54] #1311732 Fri May 24 2019 02:25 AM
Kilted54 Offline OP
Thanks for input - I can’t remember were I heard the suggestion... kinda why I asked,
I got the info I was looking for
Re: Removing front clip or not? [Re: Kilted54] #1311739 Fri May 24 2019 03:12 AM
Fox Offline
That’s what apprentices are for!
More pictures here
1953 GMC 9430 1 ton dually—-Shiny!
1970 Chevrolet C10 - Grandpa’s- My first truck.—in progress to shiny
1972 Chevrolet C20- rusted
1970 Chevrolet K20 Suburban—rusted.
1950 Chevrolet 1300- in progress to shiny.
Parts trucks-
1951 GMC 9300
1951-GMC 9430
1951- Chevrolet 1300
Moderated by  Justhorsenround
Powered by UBB.threads™ PHP Forum Software 7.7.3
