The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
1 registered members (1 invisible), 268 guests, and 2 spiders.
Forums47
Topics115,013
Posts912,553
Members42,079
Most Online940
Apr 5th, 2017
Image Posting Policy
Throwout Bearing Noise #1311073
Sat May 18 2019 05:32 PM
Phak1  Offline OP
Upstate NY
I have a noise then the clutch is fully released, engine running and the transmission is in neutral. After reading several post on this exact issue I think i have it pinpointed to the clutch fork and and pivot ball as the issue. The throw out bearing is still in contact with the clutch fingers.
My truck is missing the clutch cover plate so it was easy to see. The fork pulls away from the ball pivot easily. I looked in the service manual and one of the inspections for the clutch for is to check that the ball is snug and has no endplay. I’m thinking that no endplay means it can’t pull out of the socket.
Does this sound like the problem? Can the fork be pulled without pulling the transmission?
1952 Chevrolet 3100 w/59’ 235
Re: Throwout Bearing Noise [Re: Phak1] #1311088
Sat May 18 2019 09:15 PM
Hotrod Lincoln  Offline
Boltergeist
Dellrose, TN
There is supposed to be a C-shaped retaining spring that fits into a groove in the throwout fork where it pivots on the ball. If it's missing, the ball can be pulled forward by the return spring, which, I believe, was also missing on your truck. Unfortunately, it's difficult, if not impossible to remove the throwout fork with the transmission in place. Some ball pivots screw into the bellhousing and have an Allen wrench socket to install them from the back side, but the head of the pivot bolt is usually covered by the front of the transmission.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: Throwout Bearing Noise [Re: Phak1] #1311091
Sat May 18 2019 09:37 PM
Phak1  Offline OP
Upstate NY
That sounds like it would account for that movement and yes I was missing that spring.
Is this the spring retainer you are talking about?
Is it installed in the fork first then popped onto the ball pivot?
Re: Throwout Bearing Noise [Re: Phak1] #1311094
Sat May 18 2019 10:38 PM
Boltergeist
Dellrose, TN
Yep, that's it! I don't know of any shortcuts for installing it- - - -just bite the bullet and do whatever it takes to remove the fork and install the spring.
Moderated by  SWEET
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
