The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
13 registered members (52Carl, Forty9, 56_3200, '54 3600, 5 Window 9434, 55 SHAKER, 1 invisible), 291 guests, and 3 spiders.
Forums48
Topics116,181
Posts923,842
Members42,360
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 1 of 2 1 2
Gas gauge issue 49 3600 #1311024 Fri May 17 2019 10:40 PM
I
imstilllarry Offline OP
So brand new gas gauge and a new sending unit. It all worked fine out of the dash with ground wire hooked up. Unhook the wire to the sending unit and it showed full then I grounded the wire and it showed empty. One caveat, to make it work correctly I had to hook the sending unit to the full side of the fuel gauge in the ignition to empty side. Bad news, after installing back into dash nothing reads on guage. Hope someone knows what I need to change. Thanks
1949 3600 216 4 speed (completely original)
Re: Gas gauge issue 49 3600 [Re: imstilllarry] #1311037 Sat May 18 2019 02:09 AM
Rusty Rod Online
Moderator - The Electrical Bay and Rocky Mountain Bolters
recheck your connections, particularly the grounds. you might have pulled a wire loose too. Is the gauge grounded to the dash?
Another quality post.
Real Trucks Rattle
Re: Gas gauge issue 49 3600 [Re: imstilllarry] #1311047 Sat May 18 2019 04:26 AM
I
Yes I checked the ground for gauge to cluster before I installed in dash.
I've been reading past post and I think I may know the problem. Someone said a new gauge had a needle drag on the cover. Just went out with a flashlight and it's definitely against the case. darn I hate taking it out again. But I'm hoping that is the problem. I'll report back.
Re: Gas gauge issue 49 3600 [Re: imstilllarry] #1311089 Sat May 18 2019 09:20 PM
I
That was the problem. Took it out and bent the interior part of the labeled cover to make clearance on all the needles. Most likely the new guage was just a little larger than the old one. Put it back together and when I pull the wire from the sender it swings to full and when tough ground it swings to empty. Connected to the sender it shows just over half and that is pretty close.
Btw, I mounted a mirror on the firewall side so I could see everything while reaching under the dash. Wow did that make it easier than trying to get my head and arms under the dash.
Re: Gas gauge issue 49 3600 [Re: imstilllarry] #1311339 Tue May 21 2019 01:19 AM
Hotrod Lincoln Offline
Boltergeist
The first thing to do when doing under dash wiring is take the seat out. Then use a cinder block and a long piece of 1 X 12 lumber to lean/lie on. Then the only difficult trick is to keep from falling asleep!
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: Gas gauge issue 49 3600 [Re: imstilllarry] #1312324 Wed May 29 2019 02:29 PM
just-a-hacker Offline
I also have an issue with my gas gauge.
It goes off normally ( to E) ,but with key on the range is between just below half when low on fuel to 3/4 when full.
just-a-hacker
'49 3100 before '99
Re: Gas gauge issue 49 3600 [Re: imstilllarry] #1312330 Wed May 29 2019 03:53 PM
tclederman Offline
Boltergeist
Original gauge and original sender?
If replacement sender, what is the ohm rating?
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 48 years
1954 3104 5-window pickup w/Hydra-Matic - part of the family for 14 years
Z-series (54/55) GMC 350 (2-ton) COE - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
Re: Gas gauge issue 49 3600 [Re: tclederman] #1312624 Fri May 31 2019 12:07 PM
original gage , replacement sender, will check ohm rating
just-a-hacker
'49 3100 before '99
Re: Gas gauge issue 49 3600 [Re: imstilllarry] #1312626 Fri May 31 2019 12:23 PM
tclederman Offline
Boltergeist
OK
the original gauge was 0-30 ohms
A "12 volt" replacement sender might be rated 0-90 ohms.
There are replacement gauges that use the original rating, and, there are replacement gauges are made to work with the newer/higher rating.
Mis-matched sender/gauge could give the readings you describe.
Tim
Re: Gas gauge issue 49 3600 [Re: tclederman] #1313281 Wed Jun 05 2019 02:09 PM
I did order 12v replacement gages and sender unit but when I get the chance I'll pull seat out and check ohms showing at tank.
Do I need to sending unit out of tank? Last time I tried it wouldn't come all the way out. (not sure how I got in in)
just-a-hacker
'49 3100 before '99
Page 1 of 2 1 2
Moderated by  Rusty Rod
Powered by UBB.threads™ PHP Forum Software 7.7.3
