The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
5 registered members (bluesman, Hotrod Lincoln, 3B, sstock, 1 invisible), 289 guests, and 3 spiders.
Forums47
Topics116,141
Posts923,577
Members42,356
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 2 of 2 1 2
Re: Yellow Fog Lights [Re: Frank50] #1311291 Mon May 20 2019 08:21 PM
Mother.Trucker Offline
There are a lot of after market lamps out there but, when it comes to original accessory lamps for the AD trucks the accessory book lists the Guide 2002 E 5 3/4'' lamps for 1949 & 1950 trucks. GM part # 986234.
I have also seen the 4 5/8" lamps { Guide 2004 E } used.
These lamps use the elaborate mounting brackets that bolt to the front bumper brackets
Re: Yellow Fog Lights [Re: Frank50] #1311293 Mon May 20 2019 08:27 PM
tclederman Offline
Boltergeist
Thanks, MT
Do you know if those had the GM script,
and/or if they were painted block, or stainless, or chromed?
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 48 years
1954 3104 5-window pickup w/Hydra-Matic - part of the family for 14 years
Z-series (54/55) GMC 350 (2-ton) COE - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
Re: Yellow Fog Lights [Re: Frank50] #1311295 Mon May 20 2019 08:29 PM
The 1951-1954 accessory books list the Guide 5" {2023} lamps as the correct accessory for the AD trucks. GM part # 986524.
These lamps use the 45 degree mounts that secure the lamps to the front splash apron only.
I have no documentation for the correct lamps for the 1947 & 1948 trucks.
Re: Yellow Fog Lights [Re: Frank50] #1311296 Mon May 20 2019 08:37 PM
The only lamps that had a GM script were the aftermarket Unity lamps & those can be used but were not an original accessory.
Re: Yellow Fog Lights [Re: Frank50] #1311309 Mon May 20 2019 09:46 PM
tclederman Offline
Boltergeist
Thanks, MT
Tim
Re: Yellow Fog Lights [Re: Frank50] #1311310 Mon May 20 2019 09:53 PM
Tiny Offline
Global Mod
On the off chance you are looking for 6v fog lamps. I have a set of Deitz lamps on my '38 that use the 4012A (amber) bulb. I don't remember the exact size but they are a bit over 5" in diameter.
Re: Yellow Fog Lights [Re: Frank50] #1311340 Tue May 21 2019 01:20 AM
Frank50 Offline OP
Thanks all. Thanks Wally, that's just the look I'm going for.
Re: Yellow Fog Lights [Re: Frank50] #1312566 Fri May 31 2019 01:35 AM
glenns towing Offline
I love that kind of old stuff. It gives me a reason to go to swapmeets. And my vehicle will drive fine without them till i find that cant resist deal. JMO
Page 2 of 2 1 2
Moderated by  Justhorsenround
Powered by UBB.threads™ PHP Forum Software 7.7.3
