The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
WELCOME
The site has expanded to include the 1973 to 1987 trucks!
Check out the new forum just for them and welcome our newest brothers and sisters with the "Rounded Line" trucks.
Encourage one another! Share what you've learned!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
8 members (Paul_WNC, Johnny N, Phak1, 78buckshot, olezippi, porsche), 241 guests, and 3 robots.
Forums58
Topics121,926
Posts983,131
Members44,343
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 653 of 705 1 2 651 652 653 654 655 704 705
Re: What did you get done on your bolt today????
BIG CHEVY 3600 #1310941 Thu May 16 2019 07:40 PM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
Been chasing one electrical gremlin after another since I completed this years section of the Resto-Mod on the ‘62 C-10. I would get the 4 way flashers fixed and move on to a finicky left front turn signal and in the process of fixing that the 4 way would quit. Then the horn quit while at the GabFest last month. Today I was determined to fix all the signal/flasher/horn problems once and for all. Cleaned grounds again and checked the circuit for the turn signal. Had flashing power to the socket but the bulb wouldn’t flash. Worked over the pins on the base of the bulb with a pair of pliers to raise them up a bit thus making better contact. It worked, I now have 4 ways and turn signals on every corner. On to the horn. Bypassed the relay and the aftermarket klaxon horn worked but the factory horn was DOA. None of the FLAPS had a relay so I had O’Reillys bring one over from one of the OKC stores. Installed the new relay, hooked up the klaxon and left the factory horn disconnected. Legal again. Fingers crossed that the repairs will hold this time.🛠
‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2)
‘39 Dodge Businessmans Coupe
USAF 1965-69 Weather Observation Tech (got paid to look at the clouds)
"I fought the law and the law won" now I are a retired one!
BIG CHEVY 3600 #1310956 Thu May 16 2019 10:19 PM
That experience you had reminds me of that old kids game “Twister” with you holding one wire over here and pressing another one with your foot.
Jim
Modern ‘science’: the wonder of a
pre-determined mind…
The ‘baseline belief’ of astronomy:
“Any day now, we’ll pick up a tiny,
coded signal from outer space. Then
we’ll know for certain that there is
intelligence out there, because coded
information does not arise by chance”
The ‘baseline belief’ of biology:
The precisely coded genetic information in
every cell would fill many books…
but we know for certain that no intelligence
could have created life.”
BIG CHEVY 3600 #1310988 Fri May 17 2019 12:02 PM
Martin, a trick I've used on old horns is to turn the tone adjustment screw while someone holds the horn button down. Amazingly enough the two steps have to be done together for results.
The above is assuming all the dirt dabber nest have been removed.
1970 340 Duster
1951 Farmall Super A
BIG CHEVY 3600 #1310991 Fri May 17 2019 12:41 PM
I didn’t have an assistant to help with the horn adjustment. The Klaxon works and the original awaits further testing/adjustments/replacement. We do have a Dirt Dabber problem so I will have to check that. Thanks
BIG CHEVY 3600 #1311010 Fri May 17 2019 03:29 PM
Awesome Grandpa
Sanded / primed ash tray and glove box door. Installed new glove box.
Replaced dome light fixture.
Installed new hood badges.
dome
door
BIG CHEVY 3600 #1311110 Sun May 19 2019 12:43 AM
I painted the logos in my hood emblem.
1951 Chevy Panel Truck
BIG CHEVY 3600 #1311967 Sun May 26 2019 03:43 AM
Today I discovered that the splash pan from a big bolt does not fit on a half ton. I was hoping to be driving it soon and now I have to wait for the new fiberglass one to arrive, then paint it then carry on. Dang!
BIG CHEVY 3600 #1311970 Sun May 26 2019 04:10 AM
Put a used gas tank sending unit in the 37 and now have a working gas gauge.
BIG CHEVY 3600 #1312109 Mon May 27 2019 08:08 PM
Wife and I have been doing a bunch of little things as we get close to having a safety done. Some brake work, a couple shocks and spring shackles recently. Just put on new hubcaps. Next 'big' item to do are the windshields (passenger side has a few rock chips/cracks).
1953 Canadian GMC 9314 w/ (factory) Chevy 235
BIG CHEVY 3600 #1312135 Tue May 28 2019 01:27 AM
After owning this truck for 7 years, I finally got original rims and a new set of tires on the truck. It looks great, and feels great driving it!
1938 Chevy 1/2 ton
She looks good at 50 yards and 35 miles per hour on a dark night.
Moderated by  Justhorsenround
