The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
7 registered members (LKetchum, Hotrod Lincoln, Alex Arrow, 3 invisible), 288 guests, and 3 spiders.
Forums47
Topics115,749
Posts919,904
Members42,330
Most Online940
Apr 5th, 2017
Image Posting Policy
Found 4:10 gear set #1310985 Fri May 17 2019 05:22 AM
GMC kid 7530 Offline OP
I finally found a drop out 4:10 rear end for my truck. I have been looking for a couple of years to replace my 4:56 locker ,I wanted to keep the locker but finding a 4:10 locker is next to impossible to find around this neck of the woods. I removed the drop out from my truck and took it to a local gear shop with my 4:10 drop out and they were able to put together a 4:10 locker using the best parts from both. My truck only has 38000 miles on it and gears and bearings were in excellent condition. This is a corporate axle with the Eaton gears in a 1962 gmc 920. I didn’t think it was possible to put the 4:10 gears on the locker and have it fit correctly. Something about the gear offset. I’m assuming it’s going to be hard now to find the correct speedo drive. Going to install this weekend and see how she goes.
1962 GMC 920 step side 261 4 spd
Re: Found 4:10 gear set [Re: GMC kid 7530] #1311007 Fri May 17 2019 02:56 PM
3B Offline
Hy GMC kid 7530, congratulations on your find, good luck with the installation. As to the speedo drive there are a couple of different ways to correct that.
Moderated by  SWEET
Powered by UBB.threads™ PHP Forum Software 7.7.3
