The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
10 registered members (EdPruss, BigBlockMan, 52Carl, Dave Gill, 55_2nd_Series, 1 invisible), 269 guests, and 4 spiders.
Forums47
Topics115,749
Posts919,943
Members42,331
Most Online940
Apr 5th, 2017
Image Posting Policy
1956 3200 Engine Swap to 350 V8 #1310841 Wed May 15 2019 06:55 PM
Jhorrick Offline OP
Moderated
Just looking for a opinion on wether I am doing this thing right. Swapping out a 6 cylinder stick to a 350 V-8 with a 700R4 behind it. I have a mock up block and a empty 700 case and have mounted it in the truck with the original front engine mounts to line up my side motor mounts. I have a 3 degree angle and seem to have plenty of clearance for a HEI . I did remove the original trans mount to make room for the 700 and going to the rear mount cross member set up. I did pull the engine forward about 1/2 inch to make sure I have enough clearance for HEI. After I have all things mounted should I put some kind of cross member back where original one was back by the spring mounts for more frame strength or will I be ok with out and is the 1/2 inch forward from original front mount location a big deal. Have not drilled holes for side mounts yet. Trans seems to have plenty of room between floor and case.
Re: 1956 3200 Engine Swap to 350 V8 [Re: Jhorrick] #1310902 Thu May 16 2019 02:32 PM
3B Offline
Hy Jhorrick, welcome, I think you should definitely reestablish the original engine rear crossmember in some configuration that will allow installation of the transmission of your choice. I don't think 1/2" forward location of the engine from stock location will cause any problems, good luck with your project.
Re: 1956 3200 Engine Swap to 350 V8 [Re: Jhorrick] #1310910 Thu May 16 2019 03:34 PM
Green_98 Offline
I'm sure it would be an upgrade. You'll have a 350 and an automatic driveline that is still greatly limited in performance by the stock rear end, steering, suspension, and braking systems smile
-Patrick
1953 Chevrolet 3100
261 / 4-speed / 4:11 / Commercial Red
Re: 1956 3200 Engine Swap to 350 V8 [Re: Jhorrick] #1310911 Thu May 16 2019 03:35 PM
Hotrod Lincoln Offline
Boltergeist
The original crossmember in the bell housing area also stabilizes the rear spring mounting brackets. It's fairly simple to fabricate a bolt-in dropped crossmember from square tubing and steel plate that gives adequate clearance for the transmission and provides stability to the frame rails.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: 1956 3200 Engine Swap to 350 V8 [Re: Jhorrick] #1310999 Fri May 17 2019 02:08 PM
V
VEW Offline
When I put a 350/700r4 in my 41, I went with cross members for both the engine and tranny.
Victor
41 3/4 Ton Pick Up (in process)
55 Grumman Kurbside (Doughboy) 235/3 on tree w/ OD
57 3100
58 C4400 Viking (Thor)
59 C4500 Short Bus (Magic Bus)
59 G3800 1 Ton Dually (Chief)
Re: 1956 3200 Engine Swap to 350 V8 [Re: Green_98] #1311003 Fri May 17 2019 02:31 PM
Jhorrick Offline OP
Moderated
Rear end is not stock and brakes have been upgraded to power disc/ drum with booster on firewall and installed Power steering with tilt column.
Moderated by  53moneypit, Woogeroo
Powered by UBB.threads™ PHP Forum Software 7.7.3
