The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Nothing new here ...
STOVEBOLT FEVER
There is no cure!
Thanks to all of you, we have been virtual for over 25 years.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
17 members (49 3100, archburycontrol, 52 Blue, 1953 panel, 87GN, 2 invisible), 260 guests, and 5 robots.
Forums47
Topics117,651
Posts941,194
Members43,017
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 7 of 7 1 2 3 4 5 6 7
Re: Welcome
John Milliman #1308519 Thu Apr 25 2019 01:20 PM
Thanks N!
Re: Welcome
John Milliman #1310899 Thu May 16 2019 01:58 PM
Anyone in the CT Fairfield County area with some good knowledge of a 3100 with 216 motor? I could use some help setting the timing, adjusting the carb and figuring out this thing with some old school tips and tricks. Thanks!
Re: Welcome
John Milliman #1311472 Wed May 22 2019 02:55 AM
Not that ritzy corner of CT!
I found that using a vacuum gauge to set the timing gave the best running motor. Warm the engine, disconnect the vacuum advance and plug any other suckers ( like wipers ), connect a gauge to the intake manifold port and adjust the timing by rotating the distributor to get max vacuum. Make sure your valves are properly set first but that's another story.
Still playing with the carb, but mostly go by the shop manual procedure, just rebuild the carb first or you are going to waste a lot of time tweaking a bad carb if it's the stock Rochester.
NHluvstruck...
1951 3100 5-window
https://stonefacegarage.wixsite.com/mysite
51 Chevy Restoration Page
Re: Welcome
John Milliman #1322667 Tue Aug 20 2019 12:35 PM
Hello all. My name is Luke. Just checking in from Connecticut. My current ride is a 1949 GMC 150. It’s basically all original except for wheels/tires and the 5.3 under the hood. Here is a pic from the goshen fairgrounds car show this past weekend.
Re: Welcome
John Milliman #1331217 Fri Oct 25 2019 10:41 PM
1953 3100 5win 325
Hello my name is Matt. Originally from SoCal but for the last 20+ here in Fairfield County, CT.
Just acquired my dream vehicle, a 1953 5 window 4 speed 3100 with a ‘59 235 engine upgrade.
I have enjoyed my short time on Stovebolt and look forward to much more of the same.
[img]https://photos.app.goo.gl/17Vq2mkmEsQvE66R8[/img]
Re: Welcome
Carpas13 #1331250 Sat Oct 26 2019 01:31 AM
Matt-nice ride................
Re: Welcome
DaveMcK38 #1344227 Thu Jan 30 2020 01:34 AM
I just recently join as well, I am down in hope valley Ri I recently retired and I’m doing a complete resto. Except mine is a 33 and all the wood is in need of replacement. Good luck on your project. I figured I would say hey, your the closest one I’ve seen on here so far?
33 Chevy 1/2 ton with all the 29-32 left overs. (Woody)
Re: Welcome
John Milliman #1344610 Sun Feb 02 2020 12:43 AM
BBMONG WELCOME YOUR VERY CLOSE TO ME IM IN WARWICK RI.
