The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
9 registered members (1Ton_tommy, Rusty Rod, BigBlockMan, Hotrod Lincoln, Hector Polanco, 1 invisible), 263 guests, and 3 spiders.
Forums47
Topics115,750
Posts919,946
Members42,331
Most Online940
Apr 5th, 2017
Image Posting Policy
Wooden blocks on 3600? #1310760 Wed May 15 2019 01:22 AM
Brian_Ostner Offline OP
When i removed my longbed stepside from our 55.2 3600 truck, i did not see any wooden block spacers between bed and frame.
Seatched thru forum back 4 pages or so, did not see any info on this......
Is my truck supposed to use the wooden blocks?
Brian
Re: Wooden blocks on 3600? [Re: Brian_Ostner] #1310860 Wed May 15 2019 10:06 PM
SavannahDog Offline
Yes it should. Their about 2" square. So look for something similar.
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
Re: Wooden blocks on 3600? [Re: Brian_Ostner] #1310951 Thu May 16 2019 09:17 PM
Dusty53 Offline
I have a 54 3600 and GM changed the frame and bed design for 1954, and no longer use wooden blocks , same for 55.1 , 55.2 . There are 8, 1/4 " thick rubber pads used in the eight bed to frame bolt locations. You can get them from several sources, Mar-K has them, their p/n 120181 , $13.00 for set of 8.
Ronnie
1954 Chevy 3604 - A work in progress...
" You can't keep dancing with the Devil and wonder why you're still in hell"
Powered by UBB.threads™ PHP Forum Software 7.7.3
