The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
16 registered members (bowtietim, 69Cuda, canuck49, Dragsix, BC59, 1 invisible), 283 guests, and 3 spiders.
Forums47
Topics115,097
Posts913,353
Members42,110
Most Online940
Apr 5th, 2017
Image Posting Policy
info needed on sourcing vacuum/fuel lines #1310833
Wed May 15 2019 06:25 PM
DannyZ  Offline OP
Brimfield Massachusetts
Any suggestions as to where I can fine new fuel / vacuum lines for 54 COE 5700?
Re: info needed on sourcing vacuum/fuel lines [Re: DannyZ] #1310864
Wed May 15 2019 11:38 PM
69Cuda  Online
Big Bolt Forum Moderator
Seattle, Wa.
Hi Danny, 1st off, I separated out your post because you had piggybacked on someone else's thread (please create your own thread, especially when changing topics). Also, that thread was 12 years old! (Kudos for searching though and finding some info from that far back!)
I am assuming you are referring to hard lines, and not just the rubber hose. I think you are going to probably have to get tubing and bend it, unless you are looking for some used stuff. If you are actually looking for used, there is a parts wanted section that you need to post in. (all buying and selling goes on in the swap meet section).
Mike
1955 Chevy 6400 ex-flatbed (no bed now!)
Re: info needed on sourcing vacuum/fuel lines [Re: DannyZ] #1310865
3B  Offline
B. C. Canada
Hy DannyZ, welcome, could you please tell us from where to where you need the lines to go and what function they will be performing?
Re: info needed on sourcing vacuum/fuel lines [Re: DannyZ] #1310938
Thu May 16 2019 07:18 PM
Hotrod Lincoln  Offline
Boltergeist
Dellrose, TN
Finding pre-bent lines for a cabover is probably going to be a lost cause. If you have the originals in somewhat intact condition, even if they're kinked or rusty, the best bet will probably be to use them as a pattern to bend up new lines from straight tubing. If not, just use a bit of logic about things- - - -the lines won't care if they're routed a little differently than original, as long as the fuel and vacuum gets to where it needs to be. Try not to route the fuel line over the top of the valve cover or too close to the exhaust manifold etc. because engine compartment heat in a COE can get pretty intense and contribute to fuel boiling in the lines, commonly called "vapor lock".
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: info needed on sourcing vacuum/fuel lines [Re: DannyZ] #1311164
Sun May 19 2019 05:01 PM
coilover  Offline
Plano, Tx
The copper/nickel metal lines are much easier to work with (usually no tubing bender needed) and resist corrosion better than steel lines. Don't ask for "Cunifer" a you will pay double just for the name. There isn't man or gun big enough to force me to ever use stainless steel lines again. As Jerry stated: route them away from heat and interference and the routing you choose makes no difference in the function.
Evan
Re: info needed on sourcing vacuum/fuel lines [Re: DannyZ] #1311254
Mon May 20 2019 02:31 PM
Lightholder's Dad  Offline
Mesa, AZ
Agree with Coilover on the advantages of copper/nickel lines. I would disagree, however, about his comments on the Cunifer brand, which is the original British manufacturer that provides for European cars. I compared the weight of a 25 foot roll of copper/nickel 1/4 inch line purchased from NAPA with the same thing in the Cunifer brand. The NAPA line weighed 40% less than Cunifer, the difference derived from the thickness of the tube wall. Now, I am not saying that the NAPA line is dangerous but any cost savings based on tube wall thickness is not right in my opinion.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
Re: info needed on sourcing vacuum/fuel lines [Re: DannyZ] #1311262
Mon May 20 2019 03:15 PM
Boltergeist
Dellrose, TN
How thin does a line have to be to be dangerous when fuel pressure of 3-5 PSI is involved, and/or 1/2 atmosphere of vacuum? Brake line pressure is another matter entirely, but even then, I can't imagine a company making something available for sale that approaches its limits of pressure in normal use. Thar's an open invitation to ambulance chasers to "Sue Me!"
Re: info needed on sourcing vacuum/fuel lines [Re: DannyZ] #1311273
Mon May 20 2019 03:54 PM
Mesa, AZ
I realize that this is an advertisement but see the bottom of the home page;
fedhillusa.com
Is a thinner gas line more prone to crack? Out of spec for a brake line but does it matter on my COE with hydrovac? A few more dollars gets you the real thing, not a Chinese knock off. As I said, I have no idea whether the thinner product is safe but for me it is an easy choice.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1951 Chevy 1/2 ton
Moderated by  69Cuda, Grigg
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
