The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
8 members (Fox, Forty9, homer52, Steelonsteel, Eureka Jim, buoymaker), 164 guests, and 3 robots.
Forums50
Topics121,045
Posts970,421
Members43,829
Most Online1,229
Jan 21st, 2020
Image Posting Policy
LS swap with front clip
#1310798 Wed May 15 2019 12:19 PM
I am thinking of pulling my 383 for a ls1. I have a 79 camaro clip in it. if anyone here has done it did you run into any major problems?
Re: LS swap with front clip
Ecratrods #1311049 Sat May 18 2019 08:50 AM
Should not be a problem. The only LS tweaks we make are the motor mount adapters ($20) and the lower coolant inlet to water pump. You can use the swivel T-stat housing or an Oldsmobile one from around the (?) 70's. The exhaust shops love these engines since the outlets clear most frames with room to spare. Have not done an LS1/Camaro clip combo but have done several with the Nova clips. You will like how many more gas stations you can pass with the LS engine IF you keep the fuel injection and electronics. Carbed LS engines aren't as thirsty as a sbc but don't get the yield on the injected ones.
Evan
Ecratrods #1311733 Fri May 24 2019 02:28 AM
Thank You coilover. Im going to change it over this winter.
Moderated by  KCMongo
