The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
10 registered members (EdPruss, BigBlockMan, 52Carl, Dave Gill, 55_2nd_Series, 1 invisible), 269 guests, and 4 spiders.
Forums47
Topics115,749
Posts919,943
Members42,331
Most Online940
Apr 5th, 2017
Image Posting Policy
'64 K-10 Transfer Case Problem #1309031 Tue Apr 30 2019 01:22 PM
C10 - C90 Bill Offline OP
A friend of mine has a '64 K-10 4X4 with the rare 3-Speed Trans. His Transfer Case is making noise and popped out of gear the other day. Trying to find out what could possibly be wrong with it. What does it sound like to you all? A member from another board suggested this place for parts. Seems like a pretty good place:
https://torqueking.com/category/1960-1966-chevy-gmc-c-k-series-trucks/
Any helpful info would be appreciated.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
Re: '64 K-10 Transfer Case Problem [Re: C10 - C90 Bill] #1309063 Tue Apr 30 2019 06:48 PM
Hambone Offline
Bought parts for my transfer case from torque king. Worked out fine. I can’t speak to what the problem might be but it might be the same issue any transmission that jumps out of gear. Others will have ideas. He has checked the physical linkages from the cab to the case?
Is it the original t221 transfer case?
HB
1966 Chevrolet K-10
Flappy Fenders
More pictures on Photobucket
1962 Chevrolet C10
Re: '64 K-10 Transfer Case Problem [Re: C10 - C90 Bill] #1309069 Tue Apr 30 2019 07:21 PM
He has thoroughly checked the linkage and it did check out fine. The truck is pretty original and we believe it has the original case. The problem seems to be on the inside for sure and I'm going to suggest that he buys a manual from Torque King for starters.
Good to hear more good things about them.
GMC 9500 Fan
Detroit Diesel Fan
Re: '64 K-10 Transfer Case Problem [Re: C10 - C90 Bill] #1309071 Tue Apr 30 2019 07:39 PM
bartamos Offline
If linkage is in fact moving the Xfer case levers into full position, then check motor mounts. Loose motor mounts can cause this. All this must be checked carefully because removing and rebuilding a T221 is difficult and expensive. If it is a divorced case it is probably a Rockwell/Timken T221. Of course it has a tag or you can post a pic if you want to know. Even a screwed up shift boot could do this. Since it is not your truck, your info to us is second hand. Very hard for us to advise with that type of info.
As HB indicates, be sure it's not the tranny slipping out, be sure all mounts for motor, tranny and xfer case are not broken or loose. The reason we are emphasizing this is the xfer cases get VERY little use/mileage (usually) and last a long time if properly lubed.
The three speed is not considered rare. It was standard. The 4 speed was an option.
An inspection would include taking off all three drive shafts and turning transfer case by hand to detect the noise. If you don't hear anything, it still could be bad bearings under load. If it is actually making noise, do not run it anymore. Extra damage can be done. I assumed the oil level was checked. Is your friend mechanically inclined? With automotive? Is this truck new to him?
Laziness is the Father of invention.
Re: '64 K-10 Transfer Case Problem [Re: C10 - C90 Bill] #1309074 Tue Apr 30 2019 08:13 PM
Hambone Offline
I have parts of the manual and may be able to figure a way to link or post. Dont need to buy. I noticed my shift lever was also bend at one point and makes contact with the transmission hump when in 2 wd position. Have him make sure lever in cab is free to full throw.
Where is this case located? I am not qualified to rebuild others but i did do mine with the help of a friend. If close i might be able to help remove from the truck and put on the bench if it comes to that. The first step would be to remove top cover and take a look inside and that is pretty easy once you get it off your chest and up on the bench.
HB
1966 Chevrolet K-10
Flappy Fenders
1962 Chevrolet C10
Re: '64 K-10 Transfer Case Problem [Re: C10 - C90 Bill] #1309091 Tue Apr 30 2019 10:44 PM
Hambone Offline
Send me / PM an email address and I can pass along some reference material.
HB
1966 Chevrolet K-10
Flappy Fenders
1962 Chevrolet C10
Re: '64 K-10 Transfer Case Problem [Re: bartamos] #1309097 Tue Apr 30 2019 11:13 PM
Oil Level was checked. I mentioned Motor Mounts to him and he says they are new, but he is going to re-check them anyway. He is actually an Old School 50 Year Mechanic and has plenty of experience, but no experience with this particular Transfer Case. The truck has been in his family for about 35 years and is totally restored. The Transfer Case problem is the first time it ever gave him any trouble.
GMC 9500 Fan
Detroit Diesel Fan
Re: '64 K-10 Transfer Case Problem [Re: Hambone] #1309099 Tue Apr 30 2019 11:15 PM
Appreciate the info. Will pass it on to him.
PM on the way.
GMC 9500 Fan
Detroit Diesel Fan
Re: '64 K-10 Transfer Case Problem [Re: C10 - C90 Bill] #1310764 Wed May 15 2019 01:53 AM
Turned out to be just a bad Bearing. With Hambone's help with the diagrams he was able to figure out the problem and bought the Bearing local. It's now installed and road tested. Working just fine again.
Thanks y'all.
GMC 9500 Fan
Detroit Diesel Fan
Re: '64 K-10 Transfer Case Problem [Re: C10 - C90 Bill] #1310779 Wed May 15 2019 02:48 AM
Hambone Offline
Glad to hear
HB
1966 Chevrolet K-10
Flappy Fenders
1962 Chevrolet C10
Moderated by  Hambone, sixtyfive c-10
Powered by UBB.threads™ PHP Forum Software 7.7.3
