The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
19 registered members (1953 panel, 3B, 4100 Fire Truck, 48bigtrucks, 5 Window 9434, '54 3600, 1 invisible), 348 guests, and 3 spiders.
Forums48
Topics116,184
Posts923,877
Members42,363
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 2 of 2 1 2
Re: 1936 differential parts [Re: 1935Masterdeluxe] #1311167 Sun May 19 2019 05:16 PM
1935Masterdeluxe Offline OP
Sorry, didn't mean to hold out. Its, a master deluxe. I took out rear end to convert it to hydraulic brakes. I got a complete rear end off a 36 Chevy master and placed it in the 35. Found out it was missing the gear shaft and the block.
Re: 1936 differential parts [Re: 1935Masterdeluxe] #1311182 Sun May 19 2019 08:00 PM
Mike B Offline
Thanks for clearing this up!
The internal parts for the EA (1935) and FA (1936) rears are the same, so take the existing EA axle apart and swap the missing parts into the FA.
Note, the axle shaft spacer block needs to be checked for clearance with the axles installed and can't have a gap larger than .014". If the gap is larger then that there were larger blocks made to reduce the gap (but finding those won't be fun). This keeps the axle "C" clips from falling out and releasing the axle from the housing while driving down the road!
Mike B smile
Re: 1936 differential parts [Re: 1935Masterdeluxe] #1311207 Sun May 19 2019 11:49 PM
Thank you Mike, for your information. Unfortunately I scrape the 35 rear end cause the guy I got it from said it was complete. So now I'm looking
Re: 1936 differential parts [Re: 1935Masterdeluxe] #1311258 Mon May 20 2019 02:54 PM
Mike B Offline
Shaft p/n 369964 1933-36 (.80" OD x 5.4" Long)
Spacer p/n 370217 1933-36 (Standard size), 1.1485"
Spacer p/n 372515 1933-36 (Wide size), ground on all 4 sides to 1.1575" and 1.1675"
Mic the space between the axles so you know which spacer to look for, remember you can have up to .014" clearance, but no more.
Mike B smile
oD
Re: 1936 differential parts [Re: 1935Masterdeluxe] #1311721 Fri May 24 2019 12:55 AM
I would like too thank everyone for there input
, help and most of all information. George was able too help me find the needle in the hay stack..
Thank you
Page 2 of 2 1 2
Moderated by  John Milliman, Tiny
Powered by UBB.threads™ PHP Forum Software 7.7.3
