The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
20 registered members (Barnfind49, 5ptstar, artinva, 5 Window 9434, 52Carl, 1 invisible), 301 guests, and 3 spiders.
Forums47
Topics116,094
Posts923,065
Members42,329
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 1 of 2 1 2
Glass bowl fuel pump #1310585 Mon May 13 2019 11:51 AM
roberts49chevy Offline OP
Hi members.
I’m about to change my fuel pump in my 49 Chevy truck (235 ci). I e cleaned the old gasket off completely. When putting the new gasket I’m planning on using a sealant on both sides of the gasket. Any other special instructions I need to know? I don’t want any gas leaks. Installation seems simple. 2 bolts into block plus connections of fuel line. Thanks.
Re: Glass bowl fuel pump [Re: roberts49chevy] #1310587 Mon May 13 2019 12:08 PM
tclederman Offline
Boltergeist
You could try to rotate the crankshaft (via harmonic balancer) until the lobe on the camshaft is a low-spot (might be hard to determine by finger-feel in the hole in the block?).
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 48 years
1954 3104 5-window pickup w/Hydra-Matic - part of the family for 14 years
Z-series (54/55) GMC 350 (2-ton) COE - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
Re: Glass bowl fuel pump [Re: roberts49chevy] #1310591 Mon May 13 2019 01:15 PM
I wasn’t aware that the arm of the fuel pump had to hit a certain low point on the crankshaft.
Re: Glass bowl fuel pump [Re: roberts49chevy] #1310592 Mon May 13 2019 01:19 PM
tclederman Offline
Boltergeist
What I described is not necessary.
It might make it easier to install the fuel pump - the arm on the pump will not be pushing against a "high spot" on the cam lobe.
Tim
Re: Glass bowl fuel pump [Re: roberts49chevy] #1310594 Mon May 13 2019 01:35 PM
Justhorsenround Offline
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
By doing as Tim suggested, it relieves some tension on the pump arm thus making it a bit easier to get the bolts started. As he also said it not necessary just requires a bit more fiddling.🛠
"I fought the law and the law won" now I are a retired one!
Support those brave men/women who stand the "Thin Blue Line" and lock up those on the wrong side of that line.
Re: Glass bowl fuel pump [Re: roberts49chevy] #1310608 Mon May 13 2019 03:50 PM
Wrenchbender Ret. Offline
Its a good idea to glue the gasket to the pump with gasket cement or trim cement. Let it dry good. that way it can't shift on you as you are installing it. You can put a light film of RTV on the other side to be sure of no leaks.
George
1956 Chevy 1/2-Ton Pickup
Re: Glass bowl fuel pump [Re: roberts49chevy] #1310810 Wed May 15 2019 02:17 PM
Frank50 Offline
The gasket most likely will not leak anyway. It came for the factory without any sealant. That is if the gasket is the right material to work with ethanol.
Re: Glass bowl fuel pump [Re: roberts49chevy] #1310838 Wed May 15 2019 06:45 PM
Hotrod Lincoln Online
Boltergeist
Which gasket are you talking about, the one between the pump and the engine block, or the one for the glass filter dome on the pump? Neither one needs any sealer at all. By introducing sealer into the mix you're more likely to create a leak, not prevent one. The pump-to-block gasket won't leak gas anyway- - - -it's there to seal oil. Use a little brush-on Permatex if it makes you feel better, but it isn't necessary as long as the sealing surfaces are clean. The cork gasket for the sight glass doesn't need any sealer, and definitely don't use some sort of rubber-base stuff like RTV! Any residue will end up in the carburetor, clogging up jets and/or causing flooding.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: Glass bowl fuel pump [Re: roberts49chevy] #1310845 Wed May 15 2019 07:27 PM
V
Volfandt Offline
Been running a glass filter fuel pump on my 49 216 for nearly 7 yrs and 23K miles. No leaks and no sealant on the glass bowl gasket. I did use alittle Aviation permatex on the pump to block gasket, mainly to hold it up while mounting the pump.
Re: Glass bowl fuel pump [Re: roberts49chevy] #1310967 Thu May 16 2019 11:29 PM
This makes sense Hotrod Lincoln. I’ll take your advice. Thanks.
Page 1 of 2 1 2
Moderated by  Woogeroo
Powered by UBB.threads™ PHP Forum Software 7.7.3
