The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
13 members (Frank50, archburycontrol, 5 Window 9434, 56_3200, Gmc101, 55 SHAKER), 161 guests, and 3 robots.
Forums50
Topics120,976
Posts969,821
Members43,809
Most Online1,229
Jan 21st, 2020
Image Posting Policy
1963 chevrolet truck automatic
#1307215 Mon Apr 15 2019 09:04 PM
1500 Offline OP
When Chevrolet came out with the new 6 cylinder motor in 1963 , they also used a different automatic transmission. I know on the earlier truck mostly GMC's that they had a 3 speed Hydro-matic" truck only" transmission. Can any one please tell me in the 1963 to 1966 trucks did they use the same new style transmission in the cars as the trucks? Is it hard to make a 1963 to1966 standard 3 speed truck into an automatic? On the earlier Chevrolet " passenger car" cast iron 2 speed power guild that came out in 1952 had three versions for the 235 six. first version was the torque tube type , second was the 55 to 57 cars, then 58 to 62. I am hoping that once 1963 came the car and the truck automatic version's were the same .Domenic
Re: 1963 chevrolet truck automatic
1500 #1307222 Mon Apr 15 2019 10:57 PM
ace skiver
“I know on the earlier truck mostly GMC's that they had a 3 speed Hydro-matic" truck only" transmission.”
That would have been a four-forward-speed truck Hydra-Matic in 1954 for Chevrolet trucks.
It was first available in one 1952 GMC model, and then available in 1953 for all GMC light trucks.
Sorry, I know nothing about Powerglides, nor about the 1963 upwards transmissions.
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
1500 #1307234 Tue Apr 16 2019 12:19 AM
Boltergeist
Some of the 230/250 engines were equipped with the aluminum case 2 speed Powerglide. ("2 speeds- - - -too low and too high!") The simplest way to put an automatic behind a 230/250/292 engine is to use the same 3 speed Turbo Hydramatic 350 that was used with the V8 engines- - - -the bellhousing bolt pattern and flywheel/flex plate is exactly the same.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
1500 #1307268 Tue Apr 16 2019 05:42 AM
Moderated
We are using GMC truck which has 3 speed Hydro-matic" in our towing service in Queens, and the first GMC models was in 1952 and then next year in 1953 for all GMC light trucks.
1500 #1307312 Tue Apr 16 2019 03:38 PM
A 700R4 or 2004R automatic overdrive transmissions are popular choices currently. You will need a rear crossmember for the mount, a modified driveshaft, trans cooler & lines, a shifter or replacement column and the kick down cable. I believe the existing bellhousing crossmember will have to be removed.
Fred
1500 #1309761 Mon May 06 2019 01:28 AM
I had a 1963 Chevy C10 with the original 283/Power Glide combination. Over the years, I put several different SBCs in it (another 283/327/400) I got tired of breaking the Power Glide, so I dropped a TH400 in it. I had to drill out the rivets holding the tail shaft support and shove it back a couple of inches, but the actual length of the transmission was close enough to use the same drive shaft. I just had to change the yoke.
1500 #1310047 Wed May 08 2019 04:42 PM
You REALLY had something misaligned or mounted wrong if you broke Powerglides. A rule of thumb with racing automatics is 450-550hp--Turbo 350, 550-750hp--Turbo 400 above that a PG since 5,000hp blown fuel engines don't seem to hurt them. The bell housing area would crack if mounted wrong but they have after market cases to handle that. The 63 a/t for cars and trucks were the same for Powerglides but once the 350 came along there is a long and short tail housing and I can't remember if the long tail housing was the truck or car unit. Brain fogs history more each year.
Evan
coilover #1310468 Sun May 12 2019 05:07 AM
Break was probably too harsh a word. I was young and dumb. I would rev it up in neutral and dump it into gear to burn out. Typical teenager. Most of the damage was done to the clutch bands. By the time I had the TH400, I had out grown that level of stupidity. Besides, I had strong enough engines to burn out with horsepower alone.
1500 #1310483 Sun May 12 2019 01:28 PM
Boltergeist
GM got smarter, too. By the time the TH 400 came along they had learned to put a check ball in the clutch housings that would move off its seat and vent a lot of the pressure if somebody attempted a kamikaze start. Unless the RPM was at idle or only slightly above when the selector was moved into gear, there was a lot of slippage and almost no go until the driver let off the gas.
Moderated by  Hambone
