The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Happy New Year
2020
A New Year
A New Decade
A New Vision
Ring in the new with some quality time with your old truck! A great time to tackle a winter project. If you do not have access to your truck, start your parts list for spring!
The days are officially getting longer now, you know!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
24 registered members (49shep, Allen Lane, 63stepsideLB, Brad Allen, 3 invisible), 312 guests, and 3 spiders.
Forums48
Topics117,042
Posts935,088
Members42,759
Most Online1,027
Dec 27th, 2019
Image Posting Policy
Page 1 of 4 1 2 3 4
'59 Roof Front/Inner Replacement Panel #1310297 Fri May 10 2019 08:39 PM
Apache1 Offline OP
See attachment item description. Who else in the competing aftermarket besides Bill's Truck parts in Ontario, Canada carries this item? Cost 144.95 advertised...not sure if that is adjusted for currency exchange. The shipping cost would be astronomical due to the high tariffs in place.
1959 Apache 3100 Fleetside SWB (Shop Truck) (modified)
Re: '59 Roof Front/Inner Replacement Panel [Re: Apache1] #1310344 Sat May 11 2019 11:41 AM
Apache1 Offline OP
Bump>fellows might I get some feedback...some help...thanks. What vendor/s here stateside might carry this panel? Surely Bill's isn't the only supplier. In my limited search I've turned up nothing positive.
Re: '59 Roof Front/Inner Replacement Panel [Re: Apache1] #1310352 Sat May 11 2019 12:52 PM
Apache1 Offline OP
Found a few leads on a replacement panel.
Re: '59 Roof Front/Inner Replacement Panel [Re: Apache1] #1310355 Sat May 11 2019 12:58 PM
CASO Offline
Give me ambiguity
or give me something else
Re: '59 Roof Front/Inner Replacement Panel [Re: Apache1] #1310374 Sat May 11 2019 03:00 PM
Apache1 Offline OP
Thanks CASO...another vendor I happened upon before I found your post is Bowtie Bits, LLC antique Truck Parts. Unfortunately, I suppose all panels are produced off shore these days.
Re: '59 Roof Front/Inner Replacement Panel [Re: Apache1] #1310529 Sun May 12 2019 10:00 PM
Apache1 Offline OP
Who has put a full inner front roof panel in the cab of a '59 TF...past or present? Any BIG concerns...advice from past mistakes in and around the "A" pillar area where the panels intersect? What I should be aware of before I start in with a cut-off wheel? I believe this particular panel is only tied in at the "A" pillar and adjacent inner roof panel. Truly wish I didn't have to cut into this area...but the full panel is rotten...pillar to pillar.
Am I correct in thinking the lip closest to the windshield is an integral part of the pinch weld?
Re: '59 Roof Front/Inner Replacement Panel [Re: Apache1] #1310636 Mon May 13 2019 10:09 PM
bartamos Offline
The only advise I have is.............ONLY use as much of the "panel" as necessary. Leave old metal that is not rusted. But I would have to see the entire inside to elaborate and confirm. I have patch repaired a lot of TF trucks, but not that piece.
Patch panel repair is pretty much all the same. All off shore parts. Need tweaking sometimes. Modified. Remove a little of the old at a time, bla bla bla.
Careful planning, measuring, template making, cutting, welding, are all the same. If you can't get behind it with a backer, you better know how to weld thin sheet metal.
I'm away on an ego trip. Will be back on Feb 30.
I'm not an Auto Mechanic, but I play one on TV.
I charge $0.02 for every opinion and I take Paypal.
Plan B is always better than plan A, by definition.
Re: '59 Roof Front/Inner Replacement Panel [Re: Apache1] #1310639 Mon May 13 2019 11:31 PM
Apache1 Offline OP
I read you loud and clear. To reiterate, do you recall whether or not the front portion is part of the overall windshield pinch weld? Thanks again.
Re: '59 Roof Front/Inner Replacement Panel [Re: Apache1] #1310643 Tue May 14 2019 12:01 AM
bartamos Offline
I believe it is but you should be able to tell when windshield removed?
Re: '59 Roof Front/Inner Replacement Panel [Re: Apache1] #1310679 Tue May 14 2019 11:38 AM
Apache1 Offline OP
Just so happens my windshield is a bit rough...a chip here and there could be original...but the rubber is shot, dry rot, split in multiple places and someone tried to keep water out by using good old silicon chalk...no go. No choice it must come out. I'm trying to approach this project cautiously...I want to get experienced input/opinions before I dive into this with both feet. I've stitched panels in place before on other hotrods with relatively good results...but I'm an amateur at best.
The GM assembly manual gives an artist view with decent orientation but I dealing with a partial panel not the full stamping.
Page 1 of 4 1 2 3 4
Moderated by  Fourbrads, HandyAndy
Powered by UBB.threads™ PHP Forum Software 7.7.3
