The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
3 registered members (Joe W, Stooby, klhansen), 278 guests, and 3 spiders.
Forums48
Topics116,172
Posts923,798
Members42,360
Most Online940
Apr 5th, 2017
Image Posting Policy
1961 C10 original axle type?? #1310296 Fri May 10 2019 08:00 PM
C10STU Offline OP
Hi I was wondering if anyone can shed some light on this, I'm trying to identify my axle, I have a 12 bolt diff cover, apparently 12 bolt ones weren't introduced until 1965??
Does anyone know what differential /axle my 61 would of had originally??
Also would it of been 5 or 6 lug axles, I have 5 lug all round
Regards Stuart
Re: 1961 C10 original axle type?? [Re: C10STU] #1310298 Fri May 10 2019 09:04 PM
Justhorsenround Offline
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
Photos would be helpful.
"I fought the law and the law won" now I are a retired one!
Support those brave men/women who stand the "Thin Blue Line" and lock up those on the wrong side of that line.
Re: 1961 C10 original axle type?? [Re: Justhorsenround] #1310301 Fri May 10 2019 09:30 PM
C10STU Offline OP
Yeah apologies for no pics I'm in Africa working, I know it's a 12 bolt truck axle it has the odd shaped cover, I can't seem to find out what the truck had originally if the 12 bolt didn't get introduced until 65??
I'm planning on changing the oil when I get home so hopefully I'll get numbers etc of the ring gear
Re: 1961 C10 original axle type?? [Re: C10STU] #1310304 Fri May 10 2019 09:58 PM
BC59 Offline
HO33 / HO35 corporate G.M. was used thru '62.
Round cover on rear, carrier housing bolts in from front, same shape a rear cover.
12 bolt, 8 7/8" ring gear axle came out in '63, has no removable carrier housing.
BC
1960 Chevy C10 driver
G.M dealer tech since 1980 & counting
Re: 1961 C10 original axle type?? [Re: C10STU] #1310309 Sat May 11 2019 12:32 AM
Hambone Offline
It would have been 6 lug front and back.
HB
1966 Chevrolet K-10
Flappy Fenders
More pictures on Photobucket
1962 Chevrolet C10
Re: 1961 C10 original axle type?? [Re: C10STU] #1310337 Sat May 11 2019 07:34 AM
C10STU Offline OP
Thanks folks I obviously have a different front end and axle, I'll try and get some serial numbers to help identify these, I have discs on front so that's obviously a conversion,
Regards Stuart
Re: 1961 C10 original axle type?? [Re: C10STU] #1310607 Mon May 13 2019 03:42 PM
Wrenchbender Ret. Offline
You must have 71 up axles. They had 5 lugs & disc brakes in front.
George
1956 Chevy 1/2-Ton Pickup
Re: 1961 C10 original axle type?? [Re: C10STU] #1310710 Tue May 14 2019 05:48 PM
Lugnutz Offline
Check the width of the rear axle from inside backing plate to the other backing plate. I’d be interested in what you get.
I’m currently parting out a 1961 C10. As I examined things, I noticed that the rear axle wasn’t original to this 1961. The X part of the X-frame makes contact with the rear swing arms with any load on the frame. The rear springs do not line up with the frame properly either.
I know that the rear axle I have is 1966-72 because of the park brake cable brackets.
What I’m getting at is that a 1963-72 rear axle is not likely gonna be a direct swap into a 1962 or earlier X-frame.
Can anyone tell me if the 1967-72 rear axles were the same width as the 1963-66?
Moderated by  Hambone, sixtyfive c-10
Powered by UBB.threads™ PHP Forum Software 7.7.3
