The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
0 registered members (), 241 guests, and 3 spiders.
Forums47
Topics115,111
Posts913,473
Members42,120
Most Online940
Apr 5th, 2017
Image Posting Policy
AD spacer thickness? #1310132
Thu May 09 2019 02:56 PM
Just Mark  Offline OP
MI
The wood spacers that support the bed on my 47 half ton are gone and I'm planning to replace the bed wood soon. I really hate the idea of ordering 4 wood blocks with a hole thru them. Any one have know how thick (tall) they need to be?
Re: AD spacer thickness? [Re: Just Mark] #1310135
Thu May 09 2019 03:06 PM
kades51  Offline
Raymond, Mississippi
Not sure if a 47 would be the same, but on my 51 3100, I cut them 2" x 2" x 2-1/8" tall out of scrap pieces of treated 4" x 4" posts. Drilled a 1/2" hole through the center, put a couple coats of back paint on them, and used a piece of gin belt (which was about 3/16" thick) as the rubber spacer. Everything lined up and the bed sits correct.
Mike
1951 3100 5 window
Re: AD spacer thickness? [Re: Just Mark] #1310160
Thu May 09 2019 06:46 PM
MI
That sounds like exactly what I was thinking. I'm betting mine is the same thickness.
Thanks!
Re: AD spacer thickness? [Re: Just Mark] #1310211
Fri May 10 2019 12:51 AM
clarsen3100  Offline
Elizabeth City, NC 27909
Mark,
The wood spacers for my 51-3100 are 2 1/8" tall, plus the 1/4"rubber isolator pads between the frame rail and the wooden blocks. I got the bed mount kit from LMC Truck, it included the blocks, isolator pads and hardware. Hope this helps.
Charlie
'51 3100 5-Window (Restomod in progress)
Re: AD spacer thickness? [Re: Just Mark] #1310277
Fri May 10 2019 03:23 PM
MI
Yes it does. Thanks.
Mark
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
