The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
WELCOME
The site has expanded to include the 1973 to 1987 trucks!
Check out the new forum just for them and welcome our newest brothers and sisters with the "Rounded Line" trucks.
Encourage one another! Share what you've learned!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
10 members (EdPruss, buoymaker, Justhorsenround, Jon G, K. Galloway, 1 invisible), 298 guests, and 3 robots.
Forums59
Topics122,956
Posts992,110
Members44,569
Most Online1,229
Jan 21st, 2020
Image Posting Policy
1953 GMC Turnsignal ???
#1310066 Wed May 08 2019 08:35 PM
I've installed a turnsignal switch assembly on my 1953 GMC and the left front works fine and is bright, but when I try the right side both front turn signals flash but are very dim. When the 4-way flashers are activated the right front is very dim and the left front is very bright. Any help is much appreciated.
Re: 1953 GMC Turnsignal ???
buckaroo01 #1310093 Thu May 09 2019 12:53 AM
What is the brand/make and model number of the switch?
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
tclederman #1310120 Thu May 09 2019 12:29 PM
Sounds like a ground issue with the right light
1949 3100
buckaroo01 #1310150 Thu May 09 2019 05:13 PM
I checked and there is not a brand/ model number on the switch. I purchased it from Classic Parts and the wiring harness for a one wire alternator. It attaches to the steering column and the 4-way flasher has a red knob that pulls out. It has 7 wires. The wires from the parking lamps: 1 goes to the terminal board on the fender well, and the other goes to the switch. It follows the old post by KCMONGO that has a colored and numbered wiring diagram for 47-53
buckaroo01 #1310159 Thu May 09 2019 06:22 PM
Sir Searchalot
As TRUCKBIZ said. It's the ground. Probably the ground of the right front bulb socket/housing/body attachment. Run a test wire from the battery ground post to various metal spots in and around the lamp while it's set on blink. Start with touching directly on the bulb case. If that makes it all work, then find out where it is loosing ground from bulb case to body/battery.
Bulb case: The brass part of the bulb that the glass is attached to. Take off the lens to get access to it with a test wire probe.
Repair: (if testing confirms ground issue at bulb)
1. Examine attachment method of the lamp components.
2. Look for looseness, corrosion, rust. Clean/burnish or replace bulb socket and housing.
3. Compare to other side to see if anything is missing/damaged.
4. Be sure bulb bayonet pins have good contact to socket.
5. Add a ground wire.
If you are saying that both front signals flash when just the right is activated, that means the right is looking for ground and may be feeding back thru the other bulb. It's weird, but that's what it does sometimes.
Of course, there is the possibility that you have made a wiring error.
You never said anything about what the rear lamps are doing.
Does the right rear signal working properly?
Does the left front and rear work properly?
The ONLY issue is that when right is activated, both front lamps blink and......... when hazard is activated, right is dim. No issue with rear. Correct?
6V or 12V?
Watch out for careful drivers!!!
I'm away on an ego trip. Will be back on Feb 30.
I'm not an Auto Mechanic, but I play one on TV.
I charge $0.02 for every opinion and I take Paypal.
Plan B is always better than plan A, by definition.
You can't teach a new dog old tricks.
buckaroo01 #1310262 Fri May 10 2019 01:00 PM
Sorry, I should have mentioned the rear tail lights. The rear tail lights are functioning as they should, either right or left only and with the 4-way. That is correct that when the right front is activated both front lamps blink, but very, very dim.
buckaroo01 #1310382 Sat May 11 2019 04:08 PM
Bartamos, thank you for the great information and step-by-step how to. I found where I didn’t have the ground. I added a wire and all works fine. This forum is fantastic with a wealth of information
buckaroo01 #1310403 Sat May 11 2019 07:19 PM
Sir Searchalot
Good job in finding the problem. Happy to help. TRUCKBIZ called it.
Moderated by  Rusty Rod
