Stovebolt is pleased to support the Salvation Army! We're doing fine but many around the World are not. Instead of making a contribution to us this holiday season, how about making your contribution to a great organization with a long history of helping people in need around the world?
Forums48
Topics116,484
Posts929,850
Members42,644
Most Online940 Apr 5th, 2017
AD spacer thickness?
#1310132
Thu May 09 2019 02:56 PM
OP
The wood spacers that support the bed on my 47 half ton are gone and I'm planning to replace the bed wood soon. I really hate the idea of ordering 4 wood blocks with a hole thru them. Any one have know how thick (tall) they need to be?
Re: AD spacer thickness?
[Re: Just Mark]
#1310135
Thu May 09 2019 03:06 PM
Not sure if a 47 would be the same, but on my 51 3100, I cut them 2" x 2" x 2-1/8" tall out of scrap pieces of treated 4" x 4" posts. Drilled a 1/2" hole through the center, put a couple coats of back paint on them, and used a piece of gin belt (which was about 3/16" thick) as the rubber spacer. Everything lined up and the bed sits correct.
Mike
1951 3100 5 window
[Re: Just Mark]
#1310160
Thu May 09 2019 06:46 PM
OP
That sounds like exactly what I was thinking. I'm betting mine is the same thickness.
Thanks!
[Re: Just Mark]
#1310211
Fri May 10 2019 12:51 AM
Mark,
The wood spacers for my 51-3100 are 2 1/8" tall, plus the 1/4"rubber isolator pads between the frame rail and the wooden blocks. I got the bed mount kit from LMC Truck, it included the blocks, isolator pads and hardware. Hope this helps.
Charlie
'51 3100 5-Window (Restomod in progress)
[Re: Just Mark]
#1310277
Fri May 10 2019 03:23 PM
OP
