The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
11 registered members (cmayna, DoubleDingo, Ecratrods, 57 Apache Stock, 3 invisible), 273 guests, and 3 spiders.
Forums47
Topics115,749
Posts919,904
Members42,330
Most Online940
Apr 5th, 2017
Image Posting Policy
Ammeter wiring for 1952 3100 #1310102 Thu May 09 2019 01:56 AM
Phak1 Offline OP
While chasing electrical demons on my 52 1/2 ton with a 12v conversion, I hooked up the ammeter according to the diagram in Chevrolet Truck Shop Manual and the gauge worked backwards. Meaning without running, pulling on the headlight switch showed positive (charge) and after starting, the gauge would go negative (discharge). The diagram shows the battery positive is connected to the positive side of the ammeter and the alternator is connected to the negative side. I checked voltage at the alternator and it was 14.1 volts.
I looked for a generic diagram on the internet for hooking up a ammeter and it shows the opposite. The battery positive goes the the negative terminal of the ammeter and the alternator goes the positive side of the ammeter.
I swapped the wires and it seems to function correctly. Has anybody else noticed this or am I totally wrong?
1952 Chevrolet 3100 w/59’ 235 & hydraulic lifters
Original “Three on the Tree” & 4:11 torque tube
12v w/ Alternator
Re: Ammeter wiring for 1952 3100 [Re: Phak1] #1310111 Thu May 09 2019 05:02 AM
Eureka Jim Offline
You've got it right now. I just did the same job and wired the battery to the starter and the starter to the discharge side of the gauge, while the alternator went to the charge side of the gauge. Works fine for me.
Moderated by  Rusty Rod
Powered by UBB.threads™ PHP Forum Software 7.7.3
