The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
12 registered members (gumbi, 561ton, 68ironhead, carbking, KEVINSKI, 3100Cummins), 280 guests, and 5 spiders.
Forums47
Topics115,008
Posts912,478
Members42,075
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 1 of 2 1 2
bed assembly and installation #1310043
Wed May 08 2019 04:03 PM
bluesman  Offline OP
Central Missouri
I'm finally getting to the point where I can start putting together the bed on my 53 one ton! Problem is that there are no original parts, so I'll be starting from scratch. If anyone has done this I could use all the information I can get. What order do you put things together? How many cross sills, and where do they go? Should the bed be put together off the truck then lifted on?
Given the length of this bed I assume it's pretty heavy when assembled, and I don't know how to support it while assembling, if it needs to be done off the frame.
I don't even know where to start! Any information or advice would be appreciated.
Tim
I am currently digging back in to a 1953 3800 (one ton) with a nine foot bed. I've owned it since 1979, and drove it until 1982 (or so). My wife got me involved in restoring it back in 2002, got the body removed and the frame redone, then things came up. Now I am retired and starting again. If anyone is interested I have photos on Imagur ( https://timwhiteblues.imgur.com/ ). I live way back in the woods in the Ozarks on 40 acres at the end of a 2 1/2 mile private road.
Tim
Re: bed assembly and installation [Re: bluesman] #1310055
Wed May 08 2019 05:59 PM
3800GUY  Offline
Minnesota
Tim,
Sounds like quite a project, the 9' beds are great on these old trucks and get a lot of stares as you drive by. Mine has been in our family since new but spending all it's life in Minnesota the winters have been a bit rough on it. The hardest parts to find will be the 9' sides, everything else is available new. The cross sills are more heavy duty than what was used on the 1/2 and 3/4 ton models and there are 4 of them in addition to the one directly under the tail gate. Every thing bolts together, no welding required. Nice bed wood kits are available and the metal wear strips can be purchased with the holes already punched. These beds are heavy once assembled, you will need a few people to help with the lifting. I mounted the cross sills to the frame and attached one side at a time (with help) but went relatively well. The running boards and aprons will also be a challenge to find if you don't have them. Don't give up on it though, a truck like that is great to have when your done.
Good luck on your project, and keep everyone informed on how you are coming along.
Tom
Re: bed assembly and installation [Re: bluesman] #1310065
Wed May 08 2019 08:34 PM
Harold46  Offline
Georgia
Tim,
Your link https://timwhiteblues.imgur.com/ did not work (unless you have to be a member)
. Would love to see your photos.
Click here https://www.stovebolt.com/forum/manual/StoveboltImagePolicy.pdf to see how to post on the Forum.
Suggestion, give Mar-k a call. All they do is truck beds,
https://www.mar-k.com/
Harold
Harold
Re: bed assembly and installation [Re: bluesman] #1310074
Wed May 08 2019 10:19 PM
bluesman  Offline OP
Central Missouri
3800guy
I have the bed sides (used from Jim Carter), and the original running boards and aprons, and one of the original cross rails is good. I'm going to be purchasing new front panel, tailgate, cross sills, bed wood, mounting blocks, and metal bed strips. I just am not clear on exactly where/how everything goes.
Harold46
I hadn't realized that I had to designate that posts would be public. I think I've got that fixed now. Thanks for letting me know. And It's been awhile since I updated those posts, so I will be adding more very soon.
Tim
Tim
Re: bed assembly and installation [Re: bluesman] #1310076
Wed May 08 2019 10:55 PM
Justhorsenround  Offline
Grease Monkey
El Reno, Okla
Although Mar-K does not sell the 9’ sides (you don’t need them anyway) they do have online assistance on assembly. Look through their Tip and Tricks pages.🛠
"I fought the law and the law won" now I are a retired one!
Support those brave men/women who stand the "Thin Blue Line" and lock up those on the wrong side of that line.
Re: bed assembly and installation [Re: bluesman] #1310288
Fri May 10 2019 05:39 PM
bluesman  Offline OP
Central Missouri
I looked at the Mar K site, what I found were sort of generic instructions for a GM step side. What I'm really looking for are specific measurements for where the cross sills go. There are so many holes in the frame that I have no idea where they should be mounted.
I'm still a ways away from mounting things, I still need to strip and paint the bed sides, then order the $2000 worth of parts and get them painted. But I'll need to figure out where the pieces go. I like the idea of assembling it on the frame, but I don't know how that works. Do the cross sills get bolted down first? And do the bolts holding the cross sills interfere with the bed wood? Or do the cross sill bolts go through the bed wood? Do the bed sides bolt onto the end plates of the cross sills? And on the cross sills, which way is up?
As you can see, I'm pretty well lost on this part of my project. And it doesn't help that I have a rear bumper that bolts to the fenders in addition to the running boards. I'll post a photo of the rear bumper.
Tim
rear bumper2.JPG (107 downloads)
Tim
Re: bed assembly and installation [Re: bluesman] #1310294
Fri May 10 2019 07:11 PM
tclederman  Offline
Boltergeist
Jarvisburg, NC
Tim,
I dimly recall putting a bed together in 1998.
I think you can try to determine the approximate location of cross-sills/supports by laying out the length-wise metal strips that go between the bed boards.
Lay the metal strips lengthwise in the bed - the holes in the metal strips are for bolts that go through the cross-sills?
If I am incorrect, we will soon see a correction?
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 50 years
1954 3104 5-window pickup w/Hydra-Matic - part of the family for 14 years
Z-series (54/55) GMC 350 (2-ton) COE - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
Re: bed assembly and installation [Re: bluesman] #1310333
Sat May 11 2019 04:23 AM
Gord&Fran  Offline
Mill Bay, BC, Canada
Study these pictures from Brad Allen. They helped me even though they were for a earlier truck. Brad's pictures are for a short box, but I would expect that you should get an idea how it all works. Note how the holes in the angle strips line up with the cross sills. So, if the angle strips are welded on your sides, that should help you locate the cross sills.
https://www.flickr.com/photos/advance-design_parts_co/sets/72157631884205225
Gord
1954 1/2 ton 235 4 speed
Re: bed assembly and installation [Re: bluesman] #1310334
Sat May 11 2019 04:37 AM
Lightholder's Dad  Offline
Mesa, AZ
On my '37 restoration I purchased a complete bed kit from Mar-K. The kit came with detailed instructions for assembly, which was mostly done off the truck. You place the box on the truck before most of the wood and strips are installed, and before fenders and tailgate are attached, so it was pretty easy for me and another guy to lift it on the frame. Your bed would be heavier since it is longer but I still think two people could easily do that.
I would bet that if you purchase your needed panels, tailgate, cross sills, mounting blocks and bed wood from Mar-K, they would supply instructions for your '53 bed that will be detailed enough. Give them a call,
Regards,
Kent
1937 Chevy 1/2 ton (project in progress)
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
Re: bed assembly and installation [Re: bluesman] #1310412
Sat May 11 2019 09:45 PM
Bill Marlow  Offline
Camp Commandant
Dayton, Maryland. USA
Tim, I took some pictures of my bed without most of the wood if that helps at all. Check out the '50 album in my signature below.
If I can get any other pictures or measurements let me know.
Billy
Old Dominion Stovebolt Society
Exotic Animal Division
1946 Chevrolet Cab Over Engine
1946 Chevrolet 2-ton COE
http://m.youtube.com/watch?v=q26XBoHtZH8
https://photos.app.goo.gl/Pj1WsnppKFAgAnvZ7
1959 GMC 860
https://photos.app.goo.gl/Zu3Uf7Z7qocTGJvA9
50 GMC 450 Flatbed W/W, Air Brake equipt (25% Owner)
https://youtu.be/Alw3UWzqFVU
1950 Chevrolet 3800
https://photos.app.goo.gl/jNCZiHK9QGyBs5Ko7
“ I’ve got a trailer and I’m not afraid to use it! “
Page 1 of 2 1 2
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
