The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
8 registered members (69Cuda, JiMerit Boltr#43, DennisM, Canadian_guy, 2 invisible), 277 guests, and 3 spiders.
Forums47
Topics115,103
Posts913,430
Members42,115
Most Online940
Apr 5th, 2017
Image Posting Policy
I been owing the forum an update #1309712
Sun May 05 2019 08:27 PM
Tomm  Offline OP
Galesburg, KS US
I have the 70C50 that needed longer wheel studs to make "ME" feel safe as the originals lacked about a quarter inch being even with the outside end of the lug nut This was after using the wheels now 22.5" 10 bolt wheels from Wheels now. So anyway used the 704173GM, E8961 Euclid wheel studs. The knurl is moved further up the stud as pictured as well as about .004 larger diameter in the knurl area. I reamed the holes with a 3/4 drill bit (and yes my vintage miller falls 1/2 drive drill kicked my old **** several times) this was after I had tried to drive the new studs with a 8lb. short handle sledge. It still took 7 to 8 lusty swings to seat each one.
As noted I am older than my mind thinks, fat, lazy and no longer relish dirty hands. I drilled and tapped the hub between the bearing races for a 1/8" pipe plug which allows me to fill and or drain the hub without packing the bearings with grease. Have to line up between a couple studs but I had half them out at one time. Not my original idea but first seen on some IH tractors back in the early eighties during a past life.
Hope this helps someone else and the picture shows. Now on to the brake drums which are worn out. Got like new shoes though. Tom
Re: I been owing the forum an update [Re: Tomm] #1309736
Sun May 05 2019 10:27 PM
Grigg  Offline
Lexington, VA
I’d be cautious about packing the hubs full of grease on a high speed application. As things warm up and expand the extra has to go somewhere and you might grease your brakes too.
1952 Chevrolet 3800 pickup
---All pictures---
Re: I been owing the forum an update [Re: Tomm] #1309762
Mon May 06 2019 01:32 AM
7
78buckshot  Offline
Southeast Michigan
I think he is filling with gear lube instead of packing the bearings.
1957 Chevrolet 5700 LCF 283 SM420 single speed rear, 1955 IH 300U T/A, 1978 Corvette 350 auto
Re: I been owing the forum an update [Re: Tomm] #1309977
Tue May 07 2019 08:30 PM
Hotrod Lincoln  Offline
Boltergeist
Dellrose, TN
Oil-lubed hubs usually need different seals than grease-packed ones. Lots of 18-wheeler trailers do that. If you plan to run gear lube instead of grease. a conversation with a good industrial bearing and seal vendor might be a good idea.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Moderated by  69Cuda, Grigg
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
