The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
5 registered members (LKetchum, Hotrod Lincoln, Alex Arrow, 2 invisible), 298 guests, and 3 spiders.
Forums47
Topics115,749
Posts919,904
Members42,330
Most Online940
Apr 5th, 2017
Image Posting Policy
Can I change the wood without removing the bed? #1309812 Mon May 06 2019 03:12 PM
Just Mark Offline OP
I bought an oak bed wood kit with polished strips and bolts from Mar-K a few months ago. (bought a tailgate too, really great quality stuff). I'm planning to replace the plywood with the new kit within the next couple weeks. I've done two beds before, both times I removed the bed from the truck. I'm wondering if I can remove the tailgate, slide the plywood out, and replace it with the oak boards without taking the bed completely off. ? Doable? Suggestions?
Re: Can I change the wood without removing the bed? [Re: Just Mark] #1309824 Mon May 06 2019 04:06 PM
Justhorsenround Offline
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
Yes, it’s a bit fiddley but with a bit of time and patience it can be done. Painters tape is your friend if you are a one man operation. Use it to hold the bolts in place while you start the nuts. You may have to loosen up some of the bed mounting bolts. 🛠
"I fought the law and the law won" now I are a retired one!
Support those brave men/women who stand the "Thin Blue Line" and lock up those on the wrong side of that line.
Re: Can I change the wood without removing the bed? [Re: Just Mark] #1309831 Mon May 06 2019 04:47 PM
49 3100 Offline
Mark: you will have left over bolts and nuts on the sides. I did 2 beds that way, Mark K is the best. I used Watco exterior finish on the 2nd bed, better than boiled linseed oil. You need to stand up 4-5 boards in a container over night to penetrate the ends-Good Luck Bill
Re: Can I change the wood without removing the bed? [Re: Just Mark] #1309837 Mon May 06 2019 05:44 PM
Thanks guys, I feel encouraged now. I have a buddy that's gonna be helping with the install. The last bed I did I used Old Masters marine spar varnish from Bruce Horkey. I really liked it so I bought the same stuff from the same place.
I'll keep ya posted in my "SBC T5 in a 47?" thread. Hoping to do the boards starting late this week and the install maybe next week or the following week.
Re: Can I change the wood without removing the bed? [Re: Just Mark] #1310134 Thu May 09 2019 03:05 PM
cmayna Offline
Replaced my rig's old bed boards with a piece of ping pong table plywood many years ago, all by myself. If I can do that, you can replace your boards. I believe I did remove the tailgate, loosened up all the bolts which was holding the bed firmly against the frame.
Craig's '50 Chevy 3100 5 window
My truck
If I'm not working on my truck or VW camper, I'm fishing with the wife or smoking Salmon.
Re: Can I change the wood without removing the bed? [Re: Just Mark] #1311325 Mon May 20 2019 10:49 PM
WE b OLD Offline
I helped my neighbor do that very thing. There is a board kit made out of aluminum that looks like boards from LMC.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck in the Gallery
2017 Buick Encore
Pix on Photobucket
Powered by UBB.threads™ PHP Forum Software 7.7.3
