The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
15 registered members (bluesman, DennisM, Andrew7dg, alemachevyman, gsharum, HandyAndy), 302 guests, and 4 spiders.
Forums47
Topics115,012
Posts912,544
Members42,077
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 3 of 3 1 2 3
Re: Fusible link for 12v alternator [Re: Phak1] #1310147
Thu May 09 2019 04:56 PM
Hotrod Lincoln  Offline
Boltergeist
Dellrose, TN
Go ahead and attach the alternator output wire to the downstream side of the ammeter, along with the wiring to the ignition switch, light switch, fuse block (if you have one) etc. That way, the ammeter will show a battery charge/discharge indication after the alternator supplies all the current demand by the rest of the vehicle.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: Fusible link for 12v alternator [Re: Phak1] #1310217
Fri May 10 2019 01:03 AM
Phak1  Offline OP
Upstate NY
My first attempt to fabricate the shunt didn’t fair well. Although the stainless cuts easily with aviation snips, it is too hard for titanium coated drill bits in a battery powered drill. After regrouping, I was able to cut slots with a Metabo (side grinder) and a cutting wheel. Installation was easy. I placed the new shunt on first followed by the wire lugs. It worked just as the original without the shunt. It still pegs the needle on initial start but it comes down after a few seconds.
I believe this as a success. A big thanks to Jerry for steering me in the right direction.
1952 Chevrolet 3100 w/59’ 235
Re: Fusible link for 12v alternator [Re: Phak1] #1310219
Fri May 10 2019 01:24 AM
Boltergeist
Dellrose, TN
"I love it when a plan comes together!" That's a good-looking installation- - - -too bad it's going to be out of sight behind the dash soon!
Re: Fusible link for 12v alternator [Re: Phak1] #1310954
Thu May 16 2019 10:10 PM
Phak1  Offline OP
Upstate NY
I finally got to install a fusible link in the starter to ammeter 10 ga wire. I bought a 14 ga fusible link wire that had a 3/8” ring terminal already installed. That left one “Western Union Splice” to make the connection. I practiced first on some scrap 10 ga and the end of the fusible link wire that was too long. I didn’t get anywhere near 10 wraps on each side as suggested but I do believe it is a sound connection. Only time will tell. Thanks to all who helped me tackle this task.
Page 3 of 3 1 2 3
Moderated by  Rusty Rod
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
