The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
15 registered members (DennisM, 52Carl, Dave Seaver, farmall100, Hugh63c10, C10 - C90 Bill, 1 invisible), 300 guests, and 3 spiders.
Forums47
Topics115,010
Posts912,533
Members42,077
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 2 of 3 1 2 3
Re: Fusible link for 12v alternator [Re: Hotrod Lincoln] #1309861
Mon May 06 2019 09:36 PM
drdoug  Offline
Prosper, TX
Phak1, you got it. Jerry's info on the connection style is good stuff.
Here's an image if the Western Union (aka Lineman's) Splice, in case you aren't familiar. They do provide a superior joint - strong and low resistance. In cases where the wires to be spliced will be soldered, I especially like this type of splice, since it isn't reliant on just solder for mechanical strength and low resistance.
Western Union Splice.gif (142 downloads)
Re: Fusible link for 12v alternator [Re: Phak1] #1309935
Tue May 07 2019 01:10 PM
Phak1  Offline OP
Upstate NY
Would a waterproof heat shrink tubing in place of the self-vulcanizing rubber tape work as well?
1952 Chevrolet 3100 w/59’ 235
Re: Fusible link for 12v alternator [Re: Phak1] #1309940
Tue May 07 2019 02:12 PM
Hotrod Lincoln  Offline
Boltergeist
Dellrose, TN
Yes, as long as there are no wire ends sticking up to pierce the shrink tubing. I'd do both- - - - -a "belt and suspenders" approach to holding up your pants guarantees you won't moon anyone!
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: Fusible link for 12v alternator [Re: Phak1] #1309996
Wed May 08 2019 12:24 AM
Phak1  Offline OP
Upstate NY
Thanks all for your help. Great forum, great people!
Re: Fusible link for 12v alternator [Re: Phak1] #1310011
Wed May 08 2019 04:25 AM
TRUCKBIZ  Offline
far north east illinois
For your consideration; I was concerned to not damage the original ammeter after I installed an alternator so I ran a wire direct from the alt. to the starter battery connection.I left the original wiring hooked up to power the dash ect. as usual. I know this renders the ammeter mostly useless but it also guarantees no damage to the ammeter or wiring as my 49 is mostly stock. It would be simple to wire the idiot light or a volt meter if you think you need to.
Sorry I don't remember what amp my alt. is, its under 100, for sure, I wanted one I could buy off the shelf at any parts store.
In this case I suppose you would want to put your fuse-able link on the starter connection and attach it to both the original wire harness and the jumper wire.
1949 3100
Re: Fusible link for 12v alternator [Re: Phak1] #1310014
Wed May 08 2019 05:18 AM
Boltergeist
Dellrose, TN
A simpler method of protecting the ammeter would be to put a shunt across the terminals to bypass some of the current flow while still allowing it to indicate charge/discharge conditions. I like to use a piece of stainless steel radiator hose clamp bent into a horseshoe shape on the ammeter terminals to carry most of the current. It has just enough resistance to shunt enough of the current through the meter to make the needle deflect.+/-.
Re: Fusible link for 12v alternator [Re: Hotrod Lincoln] #1310119
Thu May 09 2019 12:24 PM
TRUCKBIZ  Offline
I like that, improvements that go unseen.
1949 3100
Re: Fusible link for 12v alternator [Re: Phak1] #1310125
Thu May 09 2019 01:45 PM
Phak1  Offline OP
Upstate NY
Jerry,
Can you expand a little on how to fabricate this shunt.
Are you talking about the clamps that are about 1/2” wide?
Do you use the part of the clamp that is solid or the part that goes thru the screw?
I assume when you said “bent into a horseshoe”, you would also bend out tabs to attach to the terminals.
Re: Fusible link for 12v alternator [Re: Phak1] #1310131
Thu May 09 2019 02:47 PM
Boltergeist
Dellrose, TN
You've got the basic idea. Cut a strip of the clamp that's solid, about 2" long or a little more, and bend it into a "U" shape with tabs bent at right angles to the main loop. It will resemble the "Ohms" symbol used on wiring diagrams. Drill holes in the tabs to fit over the ammeter terminals. Install the shunt onto the terminals, then connect the wiring as usual. All the connections EXCEPT the wire going to the starter cable connection get attached to the downstream side of the ammeter. That way, all the current going in and out of the battery except the starter current passes through the ammeter and/or the shunt. The shunt prevents the ammeter from deflecting full scale during heavy current situations like just after starting, while still allowing enough current to take the original path to indicate a charge/discharge situation. It's a simple, inexpensive fix that protects the original ammeter from overloads.
Re: Fusible link for 12v alternator [Re: Hotrod Lincoln] #1310142
Thu May 09 2019 04:11 PM
Phak1  Offline OP
Upstate NY
Thanks! I’ve got my gauge cluster out so I’m going to do this upgrade now. I report back how it went.
Thanks again!
Page 2 of 3 1 2 3
Moderated by  Rusty Rod
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
