The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
13 registered members (BigBlockMan, GasHog, 4100 Fire Truck, fonz8261, '54 3600, 1 invisible), 332 guests, and 3 spiders.
Forums48
Topics116,183
Posts923,875
Members42,363
Most Online940
Apr 5th, 2017
Image Posting Policy
Pawpaws Truck #1309297 Thu May 02 2019 09:31 PM
MikeSartor Offline OP
Moderated
Recently acquired my wife’s grandads truck. It set out in the pasture for over 50 years. It had sunk down in the ground up to running boards. Dug out around the tires, put air in the tires (all 4 held), and pulled it out on flat ground. Pulled the truck and got the motor to turn over. But, I am thinking about putting the body on a s10 frame. I think I could use the S10 engine and drive train plus it would have disc brakes. Has anyone done a s10 frame swap? How hard was it and what problems did you encounter. All input is appreciated.
Re: Pawpaws Truck [Re: MikeSartor] #1309302 Thu May 02 2019 09:40 PM
tclederman Offline
Boltergeist
Welcome to Stovebolt.com, Mike
Click on the "Search" button that is to the left "Forum Help" button (in the "menu" right above your post).
Enter S10 in "Keyword Search Terms" (or, Enter: S10 swap)
Enjoy the reads.
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 48 years
1954 3104 5-window pickup w/Hydra-Matic - part of the family for 14 years
Z-series (54/55) GMC 350 (2-ton) COE - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
Re: Pawpaws Truck [Re: MikeSartor] #1309307 Thu May 02 2019 10:08 PM
Frank50 Offline
We all like old truck pictures, so as soon as you have permission please post some pics of it as-is. Instructions are on the lower left of this page.
Welcome by the way! smile Lots of S10 info on this site and others. A Google search of the www will yield tons of hits. The original/ first series S10 longbeds are the correct 116" wheelbase for Advance-Design (47.2-55.1) 3100 (1/2-ton) trucks.
What year/ model/ series truck is it?
Re: Pawpaws Truck [Re: Frank50] #1309380 Fri May 03 2019 01:17 PM
Moderated
PawPaws truck is a 1951- 100 series. 228 engine, 3 speed on column. Think it is a short bed even though the box is 6’4”.
Re: Pawpaws Truck [Re: MikeSartor] #1309756 Mon May 06 2019 12:28 AM
Frank50 Offline
Sorry, I assumed it was a Chevy, not a GMC. Good luck.
Moderated by  KCMongo
Powered by UBB.threads™ PHP Forum Software 7.7.3
