The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
9 registered members (bluedot38, Hotrod Lincoln, Lightholder's Dad, Dusty, 49nut, buoymaker), 297 guests, and 3 spiders.
Forums47
Topics115,749
Posts919,905
Members42,330
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 4 of 11 1 2 3 4 5 6 10 11
Re: 1950 4400 [Re: Dcurtis] #1309489 Sat May 04 2019 12:31 PM
Dcurtis Offline OP
No worries there as of yet. It is titled. But it’s titled to the serial number of the block. Even on the original title which I have a copy of. So I do have to find out about how to change that if the block is shot. And I do agree it very likely is but I haven’t gotten into it yet
Dan
Re: 1950 4400 [Re: Dcurtis] #1309514 Sat May 04 2019 02:39 PM
tclederman Offline
Boltergeist
Yes, (as you indicated) when you title it by the original block, ask your DMV what you should do when you change the block.
See if you can get their instructions in writing, and/or, send them a registered letter with your understanding of their instructions.
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 48 years
1954 3104 5-window pickup w/Hydra-Matic - part of the family for 14 years
Z-series (54/55) GMC 350 (2-ton) COE - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
Re: 1950 4400 [Re: Dcurtis] #1309525 Sat May 04 2019 04:36 PM
2ManyTrucks Offline
Well don’t get too down until you got solid data...
I needed a 235 temporary replacement for my original 216, the best candidate in my junk car pile was an engine that last ran in 1980,
After removing a gallon of cherry pits and mice nests, from inside, I gas washed the rockers and valves and oil pan, sprayed oil on it, hammered all the valves free with wd-40, pounded some bent push rods straight-er...
And that’s the engine I’ve been running for about 3 summers now. It leaks coolant out the side of the casting a bit, this engine also froze a bit with water in it one fall back in the late 70s, I’m gonna use jbweld to seal that up one of these days.
-s
1430s, 1420, 9430
-2MT
Re: 1950 4400 [Re: Dcurtis] #1309572 Sat May 04 2019 11:31 PM
truckernix Offline
I will say that getting an old motor unstuck and getting it running is one of the most fun filled things I have ever done. My truck sat in a field for over 17 years and I got it going. It didn't have nests inside but it was stuck at first.I did an in place rebuild and put about 40K miles on it. Last year I pulled it, had the block tanked and bored and it is like new.
1951 1 Ton Completed
Re: 1950 4400 [Re: Dcurtis] #1309576 Sun May 05 2019 12:30 AM
Dcurtis Offline OP
I did a little more inspection today after work. The rockers are very rusty to the point of rust is scaling off them I think the head has rusted itself into one solid piece I really don’t know if I’ll even be able to remove the head bolts. Going to clean the rest of the mouse hotel tomorrow after work and try removing the bolts before I even start with the manifold bolts.
Dan
Re: 1950 4400 [Re: Dcurtis] #1309945 Tue May 07 2019 02:46 PM
Dcurtis Offline OP
Ok I think I have decided on the path this truck is going to go on after a week of thinking and discovery !
It’s probably going to be a few weeks before I can get it into the shop as my son and his buddy are working on a 97 mustang. So I’m going to leave the truck out behind the barn until then, and just keep spraying every nut and bolt with penetrating oil every day or so hopefully that will help with some of the worst bolts.
In the meantime lots of research and questions!!
I’m still looking for a repair manual anyone have an opinion on where to find the best one ?
Here’s a picture of the rear anyone know what the bent up bracket is ? Im thinking it was a spare tire holder but not to sure !
Dan
Re: 1950 4400 [Re: Dcurtis] #1309949 Tue May 07 2019 03:03 PM
tclederman Offline
Boltergeist
The 1947-1951/52 Chevrolet Truck Shop Manual is on-line.
It is also available in reproduction (hardcopy & CD-ROM) from many parts vendors.
You might want to visit the Tech Tips section (on top-line menu above). Lot of good advice and information there (especially in Getting Started).
Tim
Re: 1950 4400 [Re: Dcurtis] #1309950 Tue May 07 2019 03:08 PM
tclederman Offline
Boltergeist
My bad/wrong guess is that bent bar is an "add-on".
You have a few good dents in the frame members, too?
Tim
Re: 1950 4400 [Re: Dcurtis] #1309956 Tue May 07 2019 03:38 PM
John Milliman Offline
Founder/Developer
The bent up bar *is/was* one of two that held the spare tire there.
'49 Chevrolet 3804
'70 Boston Whaler Sakonnet w/ '84 Evinrude 90
'85 Ford F-350 "The Farm Dawg"
Re: 1950 4400 [Re: Dcurtis] #1309992 Tue May 07 2019 11:04 PM
Dcurtis Offline OP
There is a add on to the frame of about 20” I assume it was for the sign that it carried for 40 years. Yes the rear crossmember is bent down a little that can easily be straightened. The main frame rails appear to be very straight and in very good condition.
John,
I really think it looks like that bent up piece was a spare tire carrier but I see no evidence of a missing second piece.
Dan
Moderated by  69Cuda, Grigg
Powered by UBB.threads™ PHP Forum Software 7.7.3
