The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
8 registered members (51sub, Eureka Jim, MNSmith, bluesman, BillK, Green_98), 293 guests, and 2 spiders.
Forums47
Topics115,102
Posts913,429
Members42,115
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 1 of 6 1 2 3 4 5 6
1950 4400 #1309123
Wed May 01 2019 01:12 AM
Dcurtis  Offline OP
SE Michigan
Hi guys
I joined this forum many years ago but I am a much bigger reader than a poster. But the time has finally come. I was able to acquire a 1950 4400. It is in very rough shape right now, and I’m not entirely sure what direction I’m going to be going in on it. The engine is currently stuck but the clutch and transmission seem to be in good shape. The wheels turn freely and the brakes kinda work. There isn’t any usable wiring left at all. My plan for now is to try getting the engine free. If I can get it moving then I will start replacing ignition and fuel systems to try getting it running.
My first question it how do I identify what engine I have ? And how do I identify the type of carb is on it.
I’m not all that computer savvy and I don’t have a computer at all. I use my phone and my iPad. I know many of my questions have probably already been asked and answered but I never seem to be able to find what I’m looking for! Also if anyone can point me in the right direction I would like to post pictures if possible.
More to come !!
Thank you !
Dan
Re: 1950 4400 [Re: Dcurtis] #1309144
Wed May 01 2019 03:41 AM
Rich'sToys  Offline
Janesville, Mn
Welcome!
For info on posting pictures look in the lower left corner of this page.
Rich
'47 Loadmaster
I got a pair of those new Memory Foam shoe inserts. Hasn't helped much- When I walk to another room, I still can't remember why.
Re: 1950 4400 [Re: Dcurtis] #1309148
Wed May 01 2019 04:06 AM
Hotrod Lincoln  Offline
Boltergeist
Dellrose, TN
Find the number that's stamped (not cast) on the machined pad just to the rear of the distributor and post that for us. Most likely a 1950 big truck would have left the factory with a spray-oiler 235 engine, but there's no telling what might have been installed since then. If it's got a sheet metal side cover on the passenger's side that extends up over the cylinder head and the spark plugs and 2 bolts in the center of the valve cover, it's either a 216 or an early 235. A short side cover and 4 bolts at the edges of the valve cover would probably make it a later model 235. The block casting number down near the fuel pump and the stamping I mentioned before will ID it accurately.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: 1950 4400 [Re: Rich'sToys] #1309165
Wed May 01 2019 10:48 AM
Dcurtis  Offline OP
SE Michigan
Thank you I didn’t see that I’ll give posting pictures a try tonight
Re: 1950 4400 [Re: Dcurtis] #1309170
Wed May 01 2019 11:46 AM
truckernix  Offline
Bracebridge Ontario Canada
Send one of us some photos and we will post them for you. We are always anxious to see photos of these old beauties! My Email is fred.nixon@sympatico.ca
1951 1 Ton Completed
Re: 1950 4400 [Re: truckernix] #1309181
Wed May 01 2019 01:21 PM
Dcurtis  Offline OP
SE Michigan
If I can’t figure it out I will but I want to try figuring out how to work it
Re: 1950 4400 [Re: Dcurtis] #1309197
Wed May 01 2019 04:31 PM
truckernix  Offline
Good job, the photos are great! So if that is a US motor, it is a 1950 to 1952, low pressure 235. That motor is unique to those years. In Canada we had 216s of the same design. The truck looks like it wants to do serious work! Congratulations on your new addition.
Re: 1950 4400 [Re: Dcurtis] #1309199
Wed May 01 2019 05:01 PM
Dcurtis  Offline OP
SE Michigan
The truck served as a sign for a local business for the last 40 years! I’m fairly sure the original engine is in it. It was still running when it became a sign but hasn’t run since the day it was parked around 78-79. I also have a photo copy of the original title issued in 1950.
It is very rough so I plan to just do little things at a time. Starting with getting the engine unstuck. After that I will get the starter rebuilt clean and rebuild the carb and replace the entire ignition system. Then hopefully I will have a runner. Does anyone know if there are print versions of repair manuals available anywhere. I have only been able to find online versions that don’t seem very helpful.
Also here’s a picture of the driver side of the engine
Re: 1950 4400 [Re: Dcurtis] #1309250
Thu May 02 2019 08:50 AM
Dcurtis  Offline OP
SE Michigan
I wrote another post yesterday with another picture and it never showed up on the thread
Re: 1950 4400 [Re: Dcurtis] #1309251
Thu May 02 2019 11:27 AM
Dcurtis  Offline OP
SE Michigan
I’ll try it again here’s the driver side of the engine.
The oil cap is missing since who knows when and some mice had taken up residence under the valve cover. So I’m thinking I’m going to pull the head to make sure nothing is in any of the cylinders and see how bad the rust is in there. So are the head bolts reusable?
Moderated by  69Cuda, Grigg
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
