EVENTS
Check in for status!
Jump over to the
Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Forums50
Topics122,138
Posts979,723
Members44,158
Most Online1,229 Jan 21st, 2020
 Intermitent Electrical misfire on #6
OP
On my '48 GMC with a later model 228 engine. I have one of those visual spark testers where the plug wire goes onto one side of the tester and the other side of the tester goes onto to the plug. Using that, I found an intermittent weak spark on #6, the engine stumbling each time the spark showed yellow in color. I switched #6 wire with one of the other wires but the miss remained on #6. I compared the resistance of each of the spark plugs and #6 was much higher than the others. I also ohmed the wires and while they seemed OK I had a fresh set on the shelf so the truck got the new wires and also a fresh set of plugs. The new wires and plugs have helped but the stumble is still there from time to time. Am I right in thinking that I should be looking at my distributor now? What am I looking for? Wobble in the shaft? Worn cam lobe? Other usual suspects? Help is appreciated! Thanks, Jim
 Re: Intermitent Electrical misfire on #6
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
Look inside the distributor cap for carbon arcing. If #6 you will find a line from the middle contact to the #6 tower. Good luck.š
Martin '62 Chevy C-10 Stepside Shortbed (Restomod in progress) '47 Chevy 3100 5 Window (long term project) ā65 Chevy Biscayne 4dr 230 I-6 one owner (Iām #2) ā39 Dodge Businessmans Coupe USAF 1965-69 Weather Observation Tech (got paid to look at the clouds)
"I fought the law and the law won" now I are a retired one! Support those brave men/women who stand the "Thin Blue Line"! Hug a cop!
OP
Thanks for the suggestion Martin. I didn't find any evidence of carbon arcing. However, the metal tab on the top of the rotor that contacts the carbon was getting kind of rusty---not a surprise here in Hawaii where it seems everything rusts---and the brass part was partially discolored black on its top side and rough to the touch as if it was burned. It also was kind of a loose fit on the distributor shaft. I dug up a new rotor and it snugged down nicely when I put it in. Could a sloppy fitting rotor cause a miss? I started the engine up and it's firing on all 6 cylinders! Since the problem was intermittent I can't declare it fixed but everything I'm doing is helping. I won't have a chance to drive it until Monday but I'll report back after I put a few miles on it. After all the things I've had to fix---$$$---it would be nice if it was just the rotor and not a worn out distributor!
I had the same problem recently. Checked the usual suspects for a missing cylinder...plug, wire, cap. I found a lot of play in the rotor, and the distributor is worn. Replacing the rotor, and adjusting the points resolved most of the problem. It still misses occasionally at idle, so I plan on replacing the distributor too. I'm guessing the accumulation of factors caused the miss. Why it occurs on #6, I can't say.
-Kevin
This is what happens when you live with a house-full of women, the wife and daughters name all the cars: 1960 Impala - "Frankie" (Frank Sinatra) 1961 Apache - " 'Mater Jr." (wrecker) 1972 SuperBeetle Convertible - "Juliet" 1976 SuperBeetle Convertible - "Olaf" 1988 Alfa Romeo Spider Veloce - "Romeo"
Check the point gap. Sometimes there is just enough runout in the dist shaft or cam to effect only one cyl. if the points are too close together. George
They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. [url=http://www.stovebolt.com/gallery/capito%20george%201956.html] 1972 Chevy c10 Cheyenne Super
Does that distributor have a grease cup on the side of it? If it does, take off the cup and make sure that the spring and friction disc which rides on the distributor shaft are all there. This assembly of parts is designed to put a specific amount of lateral pressure on the distributor shaft to eliminate shaft wobble, thus eliminating inconsistent points performance. Carl
OP
Carl, unfortunately there is no grease cup.
It should have a grease cup. Replacement distributors commonly don't come with one, but there should be a threaded plug where one belongs.
Boltergeist
Even without a grease cup, there needs to be a spring and a phenolic disc riding against the shaft inside that hole. You can install a 1/8" pipe thread grease fitting and give it a very small shot of grease at every tuneup if you desire. Jerry
The murder victim was drowned in a bathtub full of Rice Krispies and milk. The coroner blamed the crime on a cereal killer! Cringe and wail in fear, Eloi- - - - -we Morlocks are on the hunt!
