The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
12 registered members (3B, Grigg, Eileen, Eureka Jim, 51 3804, 3 invisible), 288 guests, and 3 spiders.
Forums47
Topics115,030
Posts912,758
Members42,085
Most Online940
Apr 5th, 2017
Image Posting Policy
Speedometer Cable TH350 #1308783
Sun Apr 28 2019 05:22 AM
Rusty Shackleford  Offline OP
Vancouver, BC
I have a '52 1/2 ton panel with a 350/350 combo. The speedometer worked then the needle fell off. (I'm not sure how accurate it was.) For some reason the ammeter needle moves but I don't know if it's working right. None of the other gauges work. I purchased a set of Woodward gauges from New Vintage. I purchased a Hall Effect Speed sensor but can't seem to get any pulses from it (either in the transmission or spinning with a drill so I'm assuming it's faulty and will look into another one.) The speed sensor I got had a round shaft with a tab on it. The transmission has a squared, female receptacle so I filed down the shaft on the sender (supposedly for a TH350) and was able to get it into the transmission. The original speedometer cable had been used. My questions are: Is the 'bullet' (the gear and gear housing) the same on GM automatics and standard transmissions? Would the bullet have been changed to allow the original cable to connect with the TH350? (I don't have any history on the transmission i.e.year or application.) Thanks in advance!
It's a small world, but I wouldn't want to paint it.
Re: Speedometer Cable TH350 [Re: Rusty Shackleford] #1308786
Sun Apr 28 2019 09:37 AM
miraclepieco  Offline
OR
All the TH350 speed sensors I've ever bought have square drives.
1951 Chevy Panel Truck
Moderated by  KCMongo
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
