The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
13 registered members (Canadian_guy, 49 3100, Forty9, JiMerit Boltr#43, carbking, Hotrod Lincoln), 251 guests, and 4 spiders.
Forums47
Topics115,030
Posts912,756
Members42,085
Most Online940
Apr 5th, 2017
Image Posting Policy
1954 bed side panel #1308163
Mon Apr 22 2019 10:31 PM
coilover  Offline OP
Plano, Tx
Does anyone make a reproduction side panel that has the factory molding lines on the side or are they all smooth. Thanks; Evan
Evan
Re: 1954 bed side panel [Re: coilover] #1308166
Mon Apr 22 2019 10:50 PM
Justhorsenround  Offline
Grease Monkey
El Reno, Okla
Evan, have you looked at Mar-Ks online catalog. The image of the ‘54 bed sides show the lines you refer to. Give them a call they are good folks and may be able to fix you right up.
"I fought the law and the law won" now I are a retired one!
Support those brave men/women who stand the "Thin Blue Line" and lock up those on the wrong side of that line.
Re: 1954 bed side panel [Re: coilover] #1308175
Tue Apr 23 2019 12:27 AM
tclederman  Online
Boltergeist
Jarvisburg, NC
Unless Mar-K has changed their 1954/55st pickup bed sides, they did not match the originals (as described by coilover).
54/55st - "no body lines (otherwise, like the original)" - look at page 50 on their on-line catalog
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 50 years
1954 3104 5-window pickup w/Hydra-Matic - part of the family for 14 years
Z-series (54/55) GMC 350 (2-ton) COE - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
Re: 1954 bed side panel [Re: coilover] #1308180
Tue Apr 23 2019 01:09 AM
Grease Monkey
El Reno, Okla
Page 8 Metal bed kits. Appears they have a couple of options and can custom tailor to the customer needs. I will be there Saturday for a facility tour courtesy of the former owners Mark and his wife.
Re: 1954 bed side panel [Re: coilover] #1308183
Tue Apr 23 2019 01:29 AM
tclederman  Online
Boltergeist
Jarvisburg, NC
I hope you are correct. I am just about ready to have painted some ragged old ones, because Mar-K (and others) did not have the correct 54/55st side-panel "contours".
Tim
Re: 1954 bed side panel [Re: coilover] #1308404
Wed Apr 24 2019 04:31 PM
tclederman  Online
Boltergeist
Jarvisburg, NC
Coilover & Martin: Reminder: please post here what you found-out regarding "body/fender lines" on 1954/55st bed sides.
Thanks, Tim
Tim
Re: 1954 bed side panel [Re: coilover] #1308458
Thu Apr 25 2019 01:03 AM
Greg_H  Offline
Enid Okla
I will be anxious to see the results also. I suspect what will be found is some "bead rolling" ridges and not the original style intentions. I think to get that would require a press and die that were full bed side sized. Not my area of expertise so I can easily be mistaken. My mom spent 50 years in the steel industry so maybe I should ask her sometime but again, there are probably big differences in construction steel and pressed bed sides.
Re: 1954 bed side panel [Re: coilover] #1308750
Sat Apr 27 2019 09:38 PM
Grease Monkey
El Reno, Okla
Update: Mark-K only makes flatside beds for the ‘54. The photo on page 8 of their catalog is a representation only and not the actual product. Their explanation is they never tooled up for it since it was a narrow market. Nice guys who are eager to help when they can.
Re: 1954 bed side panel [Re: coilover] #1308752
Sat Apr 27 2019 10:01 PM
tclederman  Online
Boltergeist
Jarvisburg, NC
Thanks for the report, Martin
I'll use my old-original ones, as expected.
Tim
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
