The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
2 registered members (agedhorse, 1 invisible), 291 guests, and 3 spiders.
Forums47
Topics116,106
Posts923,234
Members42,338
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 1 of 2 1 2
'59 Fleetside Tailight Housings #1308739 Sat Apr 27 2019 06:44 PM
Apache1 Offline OP
OK fellows whats the deal...how do you access these housings? The lenses are w/o screws at least not visible ones. My right side is loose and wanted to tighten things up, etc.
1959 Apache 3100 Fleetside SWB (Shop Truck)
Re: '59 Fleetside Tailight Housings [Re: Apache1] #1308751 Sat Apr 27 2019 09:49 PM
FootStomper Offline
Do you not have three screws showing in the lens?? Once removed the bucket and trim piece can be removed by the two screws top and bottom of the bulb socket.
Once you are in there, I recommend a ground strap as shown in my pictures.
~~ Darcy
1959 GMC 9310 Canadian- built Shortbox Fleetside Deluxe
FootStomper
In the Project Journals Forum
Re: '59 Fleetside Tailight Housings [Re: Apache1] #1308800 Sun Apr 28 2019 03:31 PM
Apache1 Offline OP
Footstomper>thanks for the detailed pics and comments. If you would...take a look at what I have and notice the passenger side lens is pooched out a bit more as compared to the driver sides lens. That's what caught my eye in the first place. You also see there are no screws showing so whats holding this altogether?
Re: '59 Fleetside Tailight Housings [Re: Apache1] #1308801 Sun Apr 28 2019 03:36 PM
Justhorsenround Offline
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
The lens itself is a snap fit. Using a small flat blade screwdriver gently pry the lens off. Then you can access the mounting screws. 🛠
"I fought the law and the law won" now I are a retired one!
Support those brave men/women who stand the "Thin Blue Line" and lock up those on the wrong side of that line.
Re: '59 Fleetside Tailight Housings [Re: Apache1] #1308817 Sun Apr 28 2019 07:01 PM
Apache1 Offline OP
I see...so I ought to be able to gently push on the lens to seat the one in question...correct?
Re: '59 Fleetside Tailight Housings [Re: Apache1] #1308830 Sun Apr 28 2019 09:00 PM
FootStomper Offline
Martin explained it perfectly.
Remove the red lens and you will be on your way to finding the solution.
Aside from the Blue Dot lens, this is what should be in it. Original lenses are still available.
~~ Darcy
FootStomper
Re: '59 Fleetside Tailight Housings [Re: Apache1] #1308856 Mon Apr 29 2019 01:02 AM
Apache1 Offline OP
Thanks Darcy, I just might purchase a set of Blue Dots.
Re: '59 Fleetside Tailight Housings [Re: Apache1] #1308868 Mon Apr 29 2019 02:05 AM
Just as a point of information, check your State Laws before installing “Blue Dots” in your red taillight lenses.
Re: '59 Fleetside Tailight Housings [Re: Apache1] #1308891 Mon Apr 29 2019 10:28 AM
Apache1 Offline OP
Really what statute governs the use of "Blue Dot" lenses? Why would these be a (safety) hazard?
Re: '59 Fleetside Tailight Housings [Re: Apache1] #1308900 Mon Apr 29 2019 11:40 AM
tclederman Offline
Boltergeist
Most likely, Tenn. Code Ann. § 55-9-402(d)(3)
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 48 years
1954 3104 5-window pickup w/Hydra-Matic - part of the family for 14 years
Z-series (54/55) GMC 350 (2-ton) COE - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
Page 1 of 2 1 2
Moderated by  Rusty Rod
Powered by UBB.threads™ PHP Forum Software 7.7.3
