The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
18 registered members (artinva, Barnfind49, 5ptstar, 5 Window 9434, 52Carl, 1 invisible), 300 guests, and 3 spiders.
Forums47
Topics116,094
Posts923,065
Members42,329
Most Online940
Apr 5th, 2017
Image Posting Policy
46 Half ton heater #1307721 Fri Apr 19 2019 03:23 PM
46pkup Offline OP
Hi all, I have a dilemma with the Wards heater in the old truck and looking for suggestions. Its been unhooked for at least 15 years. I believe the blower motor gave out so they just abandoned it. Touched wires directly to battery but no joy. Fan spins freely by hand. Really can't foresee getting the giant nuts lose on the firewall to remove it without damaging the heater core or destroying it. I haven't seen any units similar to replace it with. If I could remove it without damage I look at trying to rebuild it. Any suggestions. Thanks
Re: 46 Half ton heater [Re: 46pkup] #1307726 Fri Apr 19 2019 03:39 PM
Justhorsenround Offline
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
Soak the nuts with PB Blaster or Kroil several times over the course of 3-4 days. Then using the proper size wrench try to “Tighten” the nuts just a bit. Then hit it again with penetrating oil and start loosening the nuts. Bet they come off. Motors are available for the blower. 🛠
"I fought the law and the law won" now I are a retired one!
Support those brave men/women who stand the "Thin Blue Line" and lock up those on the wrong side of that line.
Re: 46 Half ton heater [Re: 46pkup] #1307749 Fri Apr 19 2019 05:28 PM
1946GMCDAN Offline
Motor replacement is easy enough. I have a new 6 volt and 12 volt heater motor I am not using. May or may not fit. Not hard to measure. Cores can be soldered or replaced.
Trombones Totem Poles And Old Trucks!
Re: 46 Half ton heater [Re: 46pkup] #1307757 Fri Apr 19 2019 06:03 PM
V
VEW Offline
Following Martin's advise will get you there. Be patient. Tighten, loosen, tighten, loosen, repeat....The metal these trucks were made with enable you to do that without rounding off the nut.
Good luck!
Victor
41 3/4 Ton Pick Up (in process)
55 Grumman Kurbside (Doughboy) 235/3 on tree w/ OD
57 3100
58 C4400 Viking (Thor)
59 C4500 Short Bus (Magic Bus)
59 G3800 1 Ton Dually (Chief)
Re: 46 Half ton heater [Re: 46pkup] #1307815 Sat Apr 20 2019 02:17 AM
46pkup Offline OP
Thanks, been soaking with PBB for a week. Problem is - if you look closely at heater2 pic, there are 4 pieces showing.
The threaded center piece with the inlet/outlet pipes sticking out
A circular piece next to the firewall that just gives added support to the firewall metal
A nut tightened to the circular piece
Another nut used to lock the 1st nut from turning
The nuts are 2" or better, far bigger than basic tools. Thinness of the nuts prevents using very thick tools. Pipe wrenches and channel locks are out. I'm to the point of getting out the dremmel w/cutting disk to try and cut and split the nut
Don't ya just love working on 70 year old stuff without destroying things.
Thanks again
Re: 46 Half ton heater [Re: 46pkup] #1307850 Sat Apr 20 2019 12:53 PM
Try a pencil point propane torch before you go slicing and dicing.
Re: 46 Half ton heater [Re: 46pkup] #1307866 Sat Apr 20 2019 01:47 PM
EdPruss Offline
Don't forget, your heater core is only rated for zero or 5 psi, so a modern higher radiator pressure system will likely cause it to fail soon.
Ed
Re: 46 Half ton heater [Re: 46pkup] #1308584 Thu Apr 25 2019 10:51 PM
JiMerit Boltr#43 Offline
To bad back in the day folks didn't spring for the factory heater! Instead (like with my '46) they bought an off brand (and later another requiring even more holes) and began boring holes all over the place vs using the GM holes, probably saved $1.25! Well at least I got to practice my welding skills.
1946 1/2-Ton Chevy
Moderated by  Rusty46
Powered by UBB.threads™ PHP Forum Software 7.7.3
