The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
4 registered members (Fox, 3B, Hotrod Lincoln, Self), 304 guests, and 3 spiders.
Forums47
Topics114,990
Posts912,328
Members42,071
Most Online940
Apr 5th, 2017
Image Posting Policy
37 1/2 ton wiring harness location #1308447
Thu Apr 25 2019 12:21 AM
Bill Trotter  Offline OP
Iron River Mi.
Looking for some guidance on the location of the wiring harness that feeds the headlight on the passenger side of vehicle. I had no harness when I started my resto. Purchased a manufactured harness and looking for help on location. Have my cab set and harness down to bottom on drivers side. Since this is my first resto pictures are very helpful to me. Thanks Bill
Re: 37 1/2 ton wiring harness location [Re: Bill Trotter] #1308455
Thu Apr 25 2019 12:46 AM
Lightholder's Dad  Offline
Mesa, AZ
Bill,
The harness from the dash exits the cab above and to the right of the clutch pedal. That puts it near the left frame rail. The forward part of the harness goes along the inside of the left frame rail to just below the left side of the radiator where 3 wires for the left headlight go vertical along side the radiator to enter the headlight stand. The wires for the passenger or right headlight split off and go along the crossmember below the radiator and then go vertical along side the radiator on the right to enter the headlight stand. You will find holes in the frame and crossmember for clips to hold the harness wires, which should be enclosed within cloth loom. The vertical wires are also held in loom, and are held by clips attached to the radiator bolts.
Hope this helps,
Kent
1937 Chevy 1/2 ton (project in progress)
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
Re: 37 1/2 ton wiring harness location [Re: Bill Trotter] #1308469
Thu Apr 25 2019 01:40 AM
Iron River Mi.
Yes that will help alot. Thanks again Kent!
Moderated by  Rusty Rod
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
