The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
10 registered members (Forty9, cmayna, DoubleDingo, Ecratrods, 3 invisible), 291 guests, and 3 spiders.
Forums47
Topics115,749
Posts919,904
Members42,330
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 1 of 2 1 2
1966 steering column for automatic question #1308251 Tue Apr 23 2019 03:06 PM
JFBerg713 Offline OP
The problem is the housing for the turn signal is loose. I have search some exploder diagrams and some show a "locking ring" and some do not. On the assembly diagram of the column it will show one, but then another exploder diagram of the steering wheel, turn signal assembly, horn assembly it does not show that part. The part number is 3713031 on the column diagram.
My questions are: 1. Anyone have an idea of what I am describing? 2. If the pic is correct of the locking ring. I assume the locking ring fits in the assembly, but then how does the assembly cover attached to the ring so that the cover doesnt move?
thank you guys for helping me out.
JB
JB
Re: 1966 steering column for automatic question [Re: JFBerg713] #1308265 Tue Apr 23 2019 04:24 PM
Hambone Offline
Not sure what you are describing.
HB
1966 Chevrolet K-10
Flappy Fenders
More pictures on Photobucket
1962 Chevrolet C10
Re: 1966 steering column for automatic question [Re: JFBerg713] #1308274 Tue Apr 23 2019 05:01 PM
hmm.. OK. maybe a simple question is What does the philips screws in the signal mechanism screw too? I thought it was to something that would keep the whole assembly from moving.
JB
Re: 1966 steering column for automatic question [Re: JFBerg713] #1308289 Tue Apr 23 2019 06:33 PM
Hambone Offline
There should be 3 screws holding the turn signal mech to the housing. I need to look at my manual to describe the step and nomenclature. Does the external housing (piece that surrounds the shaft) rotate? I will look at my book this pm.
Or take to turn signal handle off and then the turn signal screws and look and work the turn signal out a bit. See what you have.
HB
1966 Chevrolet K-10
Flappy Fenders
1962 Chevrolet C10
Re: 1966 steering column for automatic question [Re: JFBerg713] #1308337 Wed Apr 24 2019 01:35 AM
Hambone Offline
Turn signal housing can be adjusted if that is what has too much free play. (?). If that is the problem, there is a screw to loosen and a twist of the housing.
Picture shows your 3 holed ring. I dont have a nomenclature or description.
HB
1966 Chevrolet K-10
Flappy Fenders
1962 Chevrolet C10
Re: 1966 steering column for automatic question [Re: JFBerg713] #1308425 Wed Apr 24 2019 08:56 PM
rfs56trk Offline
The upper part of the outer tube is slotted. The plate turns to stop inside the tube which locks the tube in place. It is secured with the 3 screws through the TS switch & collar which holds the entire upper column together.
If one or more of the lock rings are broken off the tube the retainer does not hold it in place.
Fred
Re: 1966 steering column for automatic question [Re: JFBerg713] #1309084 Tue Apr 30 2019 09:13 PM
So upon further discovery, It seems the mast housing of the steering column has tabs that are broken off. I tried to get a picture of what I am talking about. In the pic, there are 2 tabs on the metal shroud incasing the whole column. The one I am pointing the screwdriver too and one just south of that on the metal shroud. These missing tabs are how the turn assembly housing is locked into place on the column. I do not see anyplace where a locking plate would be nor help.
My question- Being I have looked in the assembly manual, I do not see this column. I am wondering if this is the original steering column for the truck. If it isnt, Any idea of what it might be?
JB
Re: 1966 steering column for automatic question [Re: JFBerg713] #1309213 Wed May 01 2019 08:03 PM
rfs56trk Offline
It's an original. Fred
Re: 1966 steering column for automatic question [Re: JFBerg713] #1309389 Fri May 03 2019 02:29 PM
Tank you Fred,
Does anyone think I could just buy a mast? or would I end up having to buy the entire column? I am asking this because I have not seen a way to actually remove that piece.
JB
Re: 1966 steering column for automatic question [Re: JFBerg713] #1309392 Fri May 03 2019 02:42 PM
rfs56trk Offline
It all comes apart down to individual pieces. I recently rebuilt a 3 speed column and replaced that tube. However, I'm not sure where you can obtain a good tube without buying another column. It may be possible to fabricate the broken tabs and have them welded in place.
The one I replaced had one tab broken off, perhaps it could be useful.
Fred
Page 1 of 2 1 2
Moderated by  Hambone, sixtyfive c-10
Powered by UBB.threads™ PHP Forum Software 7.7.3
