The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
12 registered members (drdoug, matthews940, 55 SHAKER, beltfed, Brad Allen, cmayna), 303 guests, and 3 spiders.
Forums47
Topics116,101
Posts923,136
Members42,336
Most Online940
Apr 5th, 2017
Image Posting Policy
37 side panel latch #1308169 Mon Apr 22 2019 11:33 PM
Bill Trotter Offline OP
Already ask this question to a fellow bolter and received pics from him. Thought I would ask here to get more input. Is the rod to move the latch supposed to be straight or have a small bend? One of mine will not even move the latch when the handle on the outside is moved. I am assuming the small rod has been abused over the years and has to much of a bend in it. Thanks for any help. Bill
Re: 37 side panel latch [Re: Bill Trotter] #1308170 Mon Apr 22 2019 11:43 PM
Justhorsenround Offline
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
I know absolutely nothing about a ‘37 but my thought is, anytime you put a bend in a rod you weaken it. I believe it was originally straight. 🛠
"I fought the law and the law won" now I are a retired one!
Support those brave men/women who stand the "Thin Blue Line" and lock up those on the wrong side of that line.
Re: 37 side panel latch [Re: Bill Trotter] #1308173 Mon Apr 22 2019 11:56 PM
Thanks, any and all input on this is great. I am hoping that someone out there has one with no abuse and can verify that it is straight.
Re: 37 side panel latch [Re: Bill Trotter] #1308254 Tue Apr 23 2019 03:23 PM
Lightholder's Dad Offline
Bill,
I checked the mechanisms on my '37, both sides, and they are straight. I recall having problems with a hood latch on my '42. They are exactly like the '37 and one had bent. I straightened it and that fixed the problem. I think it comes from poorly adjusted latches and then one forces the handle, bending that rod.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
Re: 37 side panel latch [Re: Bill Trotter] #1308281 Tue Apr 23 2019 05:43 PM
Thanks Kent, I thought that mine were bent but was unsure. This forum is a great place for issues like this. Bill
Re: 37 side panel latch [Re: Bill Trotter] #1308288 Tue Apr 23 2019 06:28 PM
Kent sent you a P.M.
Re: 37 side panel latch [Re: Bill Trotter] #1308306 Tue Apr 23 2019 10:01 PM
Bill,
I am replying here so I can attach a photo. The attached picture is of the right (passenger) side. You may need to adjust the latches on the firewall and radiator surround, fore and aft, of the hood opening. These each have two bolts holding them in place with slotted openings to allow adjustment. The only way I know how to do it is by trial and error. You can observe from the other side. Good luck.
Also, the handles are horizontal on closing/latching.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1951 Chevy 1/2 ton
Re: 37 side panel latch [Re: Bill Trotter] #1308308 Tue Apr 23 2019 10:13 PM
Lee, that is exactly what I needed. My latch rods look really bent now that I see what yours look like. You have been a great help.. thanks, Bill
Re: 37 side panel latch [Re: Bill Trotter] #1308724 Sat Apr 27 2019 01:51 PM
Kent, sorry about calling you Lee, am talking to two people on this issue. After further review my handles are both vertical when closed. The pic you sent is of the passenger panel correct? Not sure why they they are wrong. I am going to try and turn hangles around. Bill
Re: 37 side panel latch [Re: Bill Trotter] #1308725 Sat Apr 27 2019 02:12 PM
Bill,
That is correct, the picture if of the inside of the passenger side of the hood. No need to apologize, it may be Lee who is offended when he finds out you confused him with ME!
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1951 Chevy 1/2 ton
Moderated by  Fourbrads, HandyAndy
Powered by UBB.threads™ PHP Forum Software 7.7.3
